Question about Gamo Pt-85 Blowback
I'd like to know how can clearing pellets that were retained in the barrel of the 85-pt
I fired the gun with the CO2 bottle almost empty and now the pellets do not come out...
The only way I found to fix this was to break the gun down and remove the barrel. Once you do that you can use a push rod to remove the pellets. By sure to push them out the way they went in.
Posted on Mar 06, 2014
The gun fires but the pellet will not leave the barrel. The barrel is clear and black smoke comes out when fired.
Assume this is a conventional air weapon powered by a spring.
I suspect the main pressure washer is defective. The gun will need dismantling and a new washer fitted. It could be wise to also replace the spring and the breech seal.
May 21, 2016 | Optics
My Crosman 1008 Repeat Air pistol leaks all CO2 out
The crosman 1008 does indeed fire pellets! NOT BBs. ONLY pellets.
Feb 03, 2014 | Crosman (4032)
Pellets jammed in the gun's barrel
The best way I found to fix this is to break the gun down. Once you've done that you can slide the barrel out and use a push rod to remove jammed pellets. To stop this issue, I've read to not use short skirted or pointed pellet.
Jan 02, 2014 | Gamo Pt-85 Blowback
How do you caulk the gun brand new, never used before. lost manual
This gun is a break barrel or break action gun. Hold the stock in your left hand and pull down on the barrel with your right. Once the barrel is down you feed your pellet right into the chamber. Pull back up to set the barrel ready to fire.
Jan 01, 2011 | Crosman Optics
Just bought a Crosman p10 pistol. Loaded the .177 pellets and the co2 cartridge.How does the co2 cartridge get punctured at the top. I don't dare tighten the screw at the bottom of the handle any tighter....
I'm not trying to be a ****-head or anything but I am thinking that the problem lies with the owner and not the gun. The very nature of your questions lead me to believe that you are a neophyte in the art of guns and gun handling. That is not a bad thing my friend, and you ARE asking questions which indicates not only intelligence but a desire to learn. No matter the subject, the person or the level of expertise referred to we all started out knowing nothing. The CO2 pistol you mention does not shoot pellets at all. It shoots steel BB's and steel BB's only. Your confusion here is understandable since the spec's on the packaging your gun came in probably designate its caliber and that would be .177. Caliber refers to the diameter of the bore of the barrel, and hence the diameter of the projectile it fires in thousands of an inch. When the average airgunner runs out of BB's in our quest to perforate all things tin, aluminum or decorated by graduated circles we don't think in terms of .177, .22, .30 or .44, we just need BB's for our BB gun and BB's only come in one size period. So, especially to a relative newcomer taking in the designation of .177 caliber on the box of your new CO2 pistol you may very well think pellet instead of BB since there is no "standard" pellet. Pellets are all referred to by their specific caliber (.177, .20, .22, .25, 5mm etc.) with .177 being by far the most prevalent.The CO2 cartridge is punctured as the screw you refer to at the bottom of the handle (grip) is turned clockwise forcing the cap (small end of the cartridge) into the perforation nozzle and surrounding seal and thereby pressurizing the chamber which provides propulsion to the projectile suited to that gun by the shooter moving the safety switch from "SAFE" to "FIRE" and cycling the trigger. I strongly suggest you locate & enroll in a basic firearms handling course and/or hunters safety course. I promise that you will never regret it. In the meantime, follow these basic rules religiously and absolutely without exception: All guns in existence ARE loaded. It doesn't matter if your Dad, sister, wife, therapist or the Pope hands you a gun and tells you it's not loaded, or if you yourself remember it to be unloaded. Keep it pointed in a safe direction, open the chamber & check, and remove or cycle (whichever is applicable to that specific firearm) the clip or magazine and check, which rolls into basic rule #2. Even when satisfied gun is indeed unloaded, ALWAYS keep it pointed in the most safe direction possible. This direction will be determined by the situation, your surroundings and common sense and can change often and rapidly. Following this rule to the letter will keep you out of trouble even if you fail miserably at rule #1 because a fully loaded, hair triggered, "Saturday Night Special" with a defective safety will not kill your son, your mom, your minister or your daughters best friend if it's not pointed at them. Never point a gun (BB, pellet, paintball, airsoft or firearm) at anything you do not want to shoot, and never put your finger on the trigger until you are completely ready to shoot. Last but not least of the basics: Be damn sure not only of your target, but also of what lies beyond it. Example: You shoot your .22 rifle at a starling sitting on a branch halfway up the pine tree in your back yard. You miss the bird, but just because you can "see" no objects of concern, does that mean there are none? A modern 40 grain .22 long rifle projectile fired from a rifle can easily travel with lethal energy in excess of a mile and a half. The result of your ignorance or laziness regarding basic rule #3 just planted that projectile in the temple of an adorable little 3rd grade girl 2 roads to the west of yours as she exited her school bus anxious to tell her mommy what a wonderful day she had. Know your guns and their associated ballistics INTIMATELY. Know your targets and what lies beyond THOROUGHLY. Never guess or make assumptions in regards to any of these rules. If there is ever even a hint of doubt in your mind, there is an absolutely foolproof, incredibly simple solution. Don't shoot.
Jul 14, 2010 | Crosman (4032)
After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Every time i set the scope the pelets hit ese
I would check your pellets.
Light pellets typically perform horrible in break barrel rifles due to their tendancy to fly around
Make sure you have a stiff, tight fitting pellet. Smaller soft pellets also will contribute to accuracy issues as they deform much and can let air escape from around the skirt when fired (called "blo by")
Jun 26, 2009 | BSA Air Gun Scopes
Bsa superten problems firing
Give BSA a call at: 01494 676740 If you're not in GB, it's an overseas call.
I know it's a dumb question (maybe), but are you sure the bolt is fully advanced and locked and the safety's off?
Mar 26, 2009 | BSA Air Gun Scopes
Gamo Pt-85 Blowback Logo
695 people viewed this question
Top Gamo Sport & Outdoor - Others Experts
Are you a Gamo Sport and Outdoor - Other Expert? Answer questions, earn points and help others
