Question about Belling XOU592 / XOU593 Electric Double Oven
Fan wont stop
Cooling fan wont stop, even if both ovens are off.
The fan doesn't turn off even the oven is not in use,the cooker is almost brand new
draft fans are not usually controlled by any front panel controls , no they work strictly by temperature , they keep going till oven cools off then shut down , now if it never stops even if oven is ice cold , then the control that feeds fan is defective and needs service
Sep 28, 2015 | Ovens
Top oven fan wont turn off unless I turn the cooker off at the mains
Cooling fan has the function to protect kitchen furniture from excessive temperature. The fan will cool the oven even you turn it off (not unplug from wall socket). This will happen only after the temperature decreasing below 70 degrees. If this does not happen then is faulty thermal cut-out which is located between wiring on the top and has 4 pins.
Dado
Sep 19, 2014 | Zanussi Ovens
Why wont fan turn off after use in oven bosch model hbn 13n5,1b
It should turn off after a while. The fan is actually the cooling of the case, it runs longer if I have used a higher temp setting. If it does not stop after app. 20 min something is broken.
Sep 03, 2014 | Bosch Ovens
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
My oven is constantly blowing out air at the front? Why
Your oven has a fan to draw in cool air at the bottom of the front panel, pass it around the case, and then blow it out at a position towards the top of the oven. This is a completely different fan that is at the back of the oven itself.
The cooling fan is necessary as the materials in modern ovens are kept light and thin as possible to save weight and manufacturing costs, however the flipside of this is that if not cooled by the cooling fan, they would be damaged by the heat inside the oven itself.
The cooling fan will continue to run for some time after the oven is switched off, because it will wait until the oven has fully cooled down before stopping the cooling fan.
Oct 03, 2009 | AEG B1180-4 Electric Single Oven
Self cleaning oven the fan will not go off after
Self cleaning ovens usually use very hot temperatures. Therefore if your fan is designed to help your oven cool, it will run until your oven is cool. Leave it running until your oven is cool and it should stop. It it does not let me know.
Jun 09, 2009 | Ovens
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Belling XOU592 / XOU593 Electric Double Oven Logo
29 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
