Question about Acer AL1917W LCD Monitor
Blue box in middle of screen has volume 100 on it
I don't have the speaker icon on my screen
Posting from a WinXP point of view. You can use this information, and crossover to the O/S you are using. (Operating System)
Click on Start > Control Panel > Sounds, Speech, and Audio Devices.
Go towards the bottom right, and click on > Sounds and Audio Devices.
In the Sounds and Audio Devices Properties window, go to the middle where it states - Device volume - in blue.
Click on the empty square box to the right of -
Place volume icon in the taskbar.
Now go below to the Right, and click on Apply.
Then go below to the Left, and click on OK.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 13, 2013 | Computers & Internet
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
Can't get rid of black box
You have your TV in the "Teletext" mode. Go into the TV menu and select the closed-captioning menu and turn off the text function. What you are seeing is the result of the TV's captioning circuit latching onto a false text pilot signal and then throwing up the black box on the screen.
michtech
Feb 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Sound problems with acer travelmate
Check the balance settings in the Volume Properties. At the bottom right of the screen you should see a Volume icon. Right click and select 'adjust volume properties'. In the box that shows up, adjust the slider bar to middle under the 'Balance' column.
If that does not work, then there could be a defect with the internal speakers. Since you only just bought the laptop, you should be able to get it replaced under warranty.
May 19, 2008 | Acer TravelMate 4072WLMi Notebook
Philips 19" monitor. volume control
damage to the board internally you need a new vga board may be a main board but I think it needs just a vga board.
May 07, 2008 | Computers & Internet
Popup on monitor screen
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
Broken Screen!
If you look on the key board cloured blue is the FN key and a monitor looking key. (remember coloured blue) press them similtaneously your external monitor should return.  On my machine it is the FN key and F4 yours mabe the same.  Please comeback and tell me how you got on.
Oct 17, 2007 | Acer Aspire 3000 Notebook
Acer AL1917W LCD Monitor Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
