Question about HEWLETT-PACKARD Computers & Internet
Turn off sound keyboard
Not working all keyboard
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
Feb 07, 2016 | Yamaha YPT-320 Keyboard
How can I turn off the sounds the keyboard makes when you hit certain keys...for instance the caps button makes a loud beep..I thought I remember when i set this keyboard I had the option of having the...
Try this Go to start click control panel and then click sounds and audio devices and click the tab named sounds and in the sound scheme click the drop down menu and select no sounds and then click on apply and click ok ..Check whether it works
Mar 08, 2011 | Gear Head WIRELESS keyboard/Mouse
The sound doesn't work I placed papers on my keyboard and it turned off the sound! Please Help! Can't work without music!!!
under the clock display is a mute button un mute it by pressing it once of go to the volume icon bottom right of the task bar and unmute it from there
Sep 07, 2010 | Logitech Cordless Desktop MX3200 Laser...
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
No sound from Yamaha keyboard
The keyboard takes only a specialist to fix the problem. Its also very delicate. The best you can do is to reset it and if the resetting does not work, then you will have to take the keyboard to a repairman to fix it for you.
Firstly, connect a headphone to the keyboard and observe if it will give a good sound. if it gives a good sound, then it means the speaker for your keyboard may have loosed contact or gotten burst.
But if it does not make any sound with the headphone, then it might be a board or sound ic problem. You can also try resetting the resetting the keyboard to default.
Turn off the keyboard, press and hold the last white key and turn the keyboard on while still holding the white key. The keyboard will then restore to its factory default.
If that doesn't solve the problem, you will have to dismantle the keyboard, use a meter to read the panel/board in order to detect the fault and do every necessary replacement. Also, you can do a deep cleaning, by cleaning all the dust in it.
If you can't do any of this, then you will end up taking is to a repairing man to fix the problem for you.
Good luck.
Jul 08, 2010 | Yamaha Full-Size Keyboard
I have the logitech keyboard and the sound will not work
I think you have a multimedia keyboard and you hear nothing when you try to use it or your keyboard is not working.Well if you remove the keyboard do you hear anything from the speakers?You might want to check the volume levels,make sure nothing is muted.The device you are trying to play make sure the levels are turned up.
Good luck
Mar 21, 2010 | Computers & Internet
Keyboard letters opkbnm not working on dell inspiron laptop,
Sounds like keyboard failure, replacement keyboards are around $20 on Ebay
Jun 23, 2009 | Computers & Internet
No audio sound after installing the keyboard software
when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Nov 18, 2008 | Logitech Cordless Desktop MX3200 Laser...
Tmobile dash instant messaging sound
my dash doesn't have instant messgaing.... what can i do to get the instant messgaing on my phone... plus the keyboard is not functioning well like it suppose to.. it works as key pad like d regular phone..but i can't use the whole keyboard...what can i do...???
Jul 07, 2008 | T-Mobile Dash Smartphone
Computers & Internet Logo
56 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
