Question about Cameras
Best picture settings for lg la55 660v - Cameras
How to get the best pcture from my lg 60 inchplasma 3d smarttv
If this is a new TV turn Off the ECO setting, It will usually be noticably brighter.And always use an HD picture source, upgrade your cable box or satellite equipment, use HDMI or component NOT channel 3
Feb 15, 2014 | LG Televison & Video
What are the best picture settings for my lg 60pv250?
http://www.avsforum.com/avs-vb/showthread.php?t=1346417
try these settings, or just mess/tinker with it until you find one that is the best. But, search AVSforum.com for LG 60PV250 and you will probably find something that is helpful.
Dec 26, 2011 | LG Televison & Video
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
I want the best picture from my 50" LG plasma tv, and I just replaced my 47" LCD LG tv with this plasma and I am not impressed at all compared to my LCD. I guess my question is what a are the best picture...
to C_LATKA:
Hi, I recently bought a 47" LCD LG the latest model and I read that you had purchased it previously and I wanted to know how you found the quality of picture on the LCD? At the moment ours is a bit blurry. I hope it was worth buying. Do you think we just need to tune the picture quality?
Jan 07, 2010 | LG 50PX5D 50 in. Plasma HDTV
WHATS THE BEST SETTINGS TO SET MY LG TV AT,AS BROUGHT A NEW ONE AND WOULD LIKE THE BEST PICTURE AND SOUND. THANKS
It depends on exacly what you have bought and what you have connected to it. best contact the delaer that you bought the LG from and get them to tell you.
Sep 10, 2009 | Televison & Video
I need settings
There are several pre-programmed settings on the picture menu,and sub menus.The best person to get the settings from is you as I could set it to my preference and you may not like it at all.
Apr 29, 2009 | LG 42LG50 42 in. LCD HDTV
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
When i set the picture mode after 5 minutes it
Sounds like a software problem, may need a firmware update. Best thing to do is take it to an Authorized LG Service Center.
Feb 18, 2009 | LG 42PX5D 42 in. Plasma HDTV
PICTIRE SETTINGS
1. you should have a HD source, such as direct tv with HD channels
2. You need to connect this source with a HDMI cable
3. Make sure all the setting match from the source to the tv
May 11, 2008 | LG 47LC7DF 47 in. LCD HDTV
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
