Question about Lenovo ThinkPad R51
Cant turn on
My computer wont turn on at all ive tryed every thing (power coard, battery, etc.)
    Problem Solver:
  • 12 Answers
Re: cant turn on
U check whether power supply coming from the terminal or not.. if its coming then u check whether SMPS fan rotating or not.. If its not rotating means u have to change ur SMPS unit.. If that also rotating means u wont do anything.. Because next steps are complicated and risky.. Check whether the system under warranty or not.. If its warranty means u ask help from the warranty providers..
Posted on Feb 12, 2008
    Problem Solver:
  • 17 Answers
Re: cant turn on
Remove all the cables and the battery hold the power button in for 20seconds then insert power and try to turn it on
Posted on Oct 30, 2013
Re: cant turn on
Chk the connections
Posted on Nov 07, 2007
0 characters
3 Points
Hp probook 6455b will not turn on why?
Take everything out of it that you can. That would mean the ram and drives, see if it boots. IF it does, then put the ram back and check it again. If it does put the hard drive back etc. If you get to the point that it wont boot with nothing installed then it could be a dead cmos battery or a loose CPU or something like that or a bad mother board.
Apr 04, 2016 | HP PC Laptops
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
Apr 07, 2015 | Dell PC Laptops
I have an acer aspire ax1430-uw30p boots up, but screen stays black, cant even see setup menu, can someone help please...
Try resetting the Bios. Remove the ram chips and if you can get access to it, the button battery on the motherboard. Wait a few minutes then put it all back in and boot up. If that won't work, try the steps at the link below, or try them first if you prefer.
Feb 18, 2015 | Acer PC Laptops
Wont start up
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 19, 2012 | Dell Latitude D505 Notebook
Laptop wont even boot up
Do you have it on a power strip? if so try resitting it,if the battery is at full charge then you have an internal problem in the laptop itself.Bad power board,etc.Hope this helps.
Jul 25, 2010 | Acer Aspire One PC Notebook
Hp pavillion dv6000 no charge or power
I would say you have destroyed the battery charger. You can get someone with a digital mulitmeter to easily check if its charging or not.
Dec 03, 2009 | HP Pavilion dv6000z Notebook
Laptop wont power up?
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 03, 2009 | PC Laptops
Acer 5620 boot up problem
check whether your hard disk is detecting on bios or not, if detecting then also check cooling fan is working or not, also check your adapter
Oct 16, 2008 | Acer Aspire 5610 Notebook
PC Laptops Logo
71 people viewed this question
Top Lenovo PC Laptops Experts
micky dee
Jay Seifried
Level 1 Expert
john smith
Are you a Lenovo PC Laptop Expert? Answer questions, earn points and help others
