Question about Kitchen Ranges
Xl44 top burners light
I have a GE Spectra XL44 stove. Model # JGBP30BEA5WH. The front right burner will click, throw a spark and light after about 10 seconds. That is the only burner that works. The other 3 will light if I use a match. The strange thing is if I try to light the other 3 using the appropriate knob, the front right burner will click and spark. I cleaned up the burners good and used sand paper to lightly clean off the stop of the ignitor.
There are a few things that can do this... First check the burner top to make sure the holes are not blocked. 2nd, Are the other ignitors sparking? If so then try rotating the slack in the burners left and right - this works sometimes. If not then try placing a screwdriver (you holding the handle only) and touch the burner and lean the screwdriver towards the ignitor... making the spark gap smaller. If you have used the ignition without a burner in place the ignition pack will short out inside it and there will not be a spark until the gap is very small. 3rd, are the ceramic part of the ignitors cracked at the base... take care when washing as they break easy if caught on the cloth. The ignition pack works in pairs so having one work suggests the pair of this one is something in the lead if there is no spark... A huge spillover causing a short or a bad earth... check the burners are firmly in place. There is more but too much detail to post here. Good luck
Posted on Jan 02, 2014
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
SOURCE: GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Posted on Mar 03, 2009
  • 8 Answers
SOURCE: No gas to the oven. Ignitor is lit. Top burners work properly.
I have the same problem. The burners work but not the oven. Ours started beeping with a FO code. The tech came out and said the control panel is bad and needs to be replaced. He also said ALOT of people are having the same problem and they might do some kind of recall down the road but for know we have to wait til Jan to get our part to fix it. Boo
Posted on Dec 10, 2009
meztang
  • 112 Answers
SOURCE: Ge Spectra Xl44-three of 4 gas burners will not ig...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
there is switch behind the knob it most be wet or it needs to be replace they are call,top burner valve switches. white in color plastic.
Nov 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top pilot light
I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 I think pilot not lit. no more snap - snap and does not light
relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Nov 21, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE XL44 Gas Stove
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
