Question about Fujitsu STYLISTIC M532 Tablet
Touch screen stops working
Tablet works fine, but screen stops working. Restarting it fixes it, then after a while, no more input is possible. Extremely annoying... .
Why has facebook stopped working and how can I get it back?
it is possible that facebook is off line ( stopped ) and will be for a time until the administrators can fix the problem
Aug 10, 2016 | Samsung Galaxy Tab 4 8.0 3G T331 16GB GSM...
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
My tablet was working fine when I brought it from Amazon now it won't coonect to my wifi it says establish reliable connection to the server, I tried other WiFi connections same message
Go to your setup setting and check your wifi setup might have change because it not storing the setting might have a problem with the tablet would replace if under warranty
Apr 20, 2015 | ProntoTec 7 Inch HD 1024x600 Capacitive...
Why did google play store stop working on my NuVision Android tablet? It was working fine.
Try to uninstall updates of play store.. Settings>apps>Google play store>uninstall updates..
Feb 11, 2015 | Tablets & eReaders
I have a asus memo pad hd 7 me137x and my problem is that my touch screen is not partly working at all i there a way that i can fix it
i do have the same problem like my touch stopped working. and nothing really happened to the tablet and i am sure that it needs a new software so could any one tell me hot to flash a new firmware in asus me137x without root
Sep 23, 2014 | Tablets & eReaders
Android keyboard (asop) has stopped working
My Kl? tablet (old one) isn't letting me use the keyboard, only a white bar shows up at the bottom. How do I fix this?
Mar 27, 2014 | Curtis ProScan 7" Capacitive Touch Screen...
Supersonic 7" Touch screen MID tablet was dropped now touch sensor not working
This may or may not be fixable without replacment parts. The hopeful solution would be to open the tablet and take a look at the ribbon cable for the digitizer to see if it was moved. Check all the cables to make sure they aren't damaged, and are seated properly. You can get parts online such as ebay if you suspect a damaged touch screen. I think these are around $25-$30.
Need tablet repair help?
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Supersonic 7" Touch Screen MID Tablet
Apps do not move to external SD
Install App2Sd(from Google playstore) and then try to move the app after restarting your phone
hope that will work
Dec 16, 2013 | Nextbook Premium 7 Capacitive Touch...
Compaq tc4400 suddenly turned into non tablet pc (pen & touch gone)
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=compaq%20tc4400&searchtype=s-002
this is where your find the moel drivers for tablet , there are two available , so please read before installing.
Nov 27, 2013 | Compaq tc4400 Tablet PC
Touch screen and digital finger scan's not working
there is one option that you have tak back-up your data then run recovery disk that is only solution becoz touch screen and finger print software is realy delicate things dont try to paly with if don't have to downlod drivers from the HP site
May 14, 2010 | HP Pavilion tx2500z Tablet PC
Fujitsu STYLISTIC M532 Tablet Logo
61 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Michael Vincent Cruz
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
