Question about Emtek 4313US15A Pewter Keyed Entry Richmond Single Cylinder Keyed
Key will not come out of lock - Emtek 4313US15A Pewter Keyed Entry Richmond Single Cylinder Keyed
I am to turn a key 1/4 turn beforekeying the lock. With a key in the lock it will not turn @ all, so a=cannot key my lock.
If you can get access to the inside of the door, the lock can be removed. Be sure you are using the correct key - try all the Kwikset keys you have. If you're completely locked out, you might need to call a locksmith.
Jul 01, 2014 | Kwikset Locks & Locksmithing
Locked
Press and hold the key programmed as
[Key Lock]
for
2 seconds to lock the transceiver keys. Press and hold the
[Key Lock]
key again to unlock the keys.
LOCKED
appears when a key is pressed while the keys
are locked
Mar 05, 2014 | Kenwood Radio Communications
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
Emtek 4313US15A Pewter Keyed Entry Richmond Single Cylinder Keyed Logo
35 people viewed this question
Top Emtek Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you an Emtek Lock and Locksmithing Expert? Answer questions, earn points and help others
