Question about Project PHONO BOX Mk2 TURNTABLE PREAMPLIFIER Amplifier
Phono box hum
Buzzing/hum noise from phono box this only happens when this box is plugged in using rega rp3 turntable
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
I have a NAD turntable. I have noticed that on occasions there seems to be a background crackle.. Thought it was dust at first !! Have swapped the connection over where the turntable plugs into the amp....
Either you have a poor earth connection or you are getting a lot of static from the records you play. The best way of getting rid of static is a spray you can get for cleaning records. Search on-line for Anti-Static Record Cleaner.
Jun 15, 2011 | NAD 533 Turntable
Faint sound slight buzzing
Connect it to the PHONO input of a receiver that has one or get a PHONO preamp and place it between the TT and your electronics.
http://en.wikipedia.org/wiki/Phonograph
May 21, 2010 | Stanton T52 Turntable
Revolver 'Rebel' Turntable extended leads Rotel RA 50 Amp - hum
could try fitting a serpresser as like cars do
also try a farraday loop which means put a few loops in your lead
Sep 07, 2009 | Audio Players & Recorders
Major feedback hum from speakers
The reason for the hum is as follows:
1) The phono input on the receiver contains an additional stage of amplification required for typical turntables.
2) Pluggin in a unit that has a signal level too high will generate this hum.
3) Your turntable contains an pre-amp that allows it to work using an aux input (or tape input) as most receivers today no longer have phono inputs.
4) Grounding issues relate to the older types of turntables where there was NO pre-amp stage inside the turntable. In this case ,the signal levels were so low that stray noise would often get in the way of the signal. Proper grounding would elimiate this noise.
Hope this helps.
Dan
Aug 10, 2009 | Sony PS-LX250 Turntable
Buzz coming from speakers on phono input
is the wire loose on either end? sometimes the electrical plugs can cause noise due to resistance, so trying different outlets might help too
Jun 21, 2009 | Technics SL-BD20D Turntable
Problems connecting turntable to amplifier
I hope you have it connected to the Phono input on the left rear of the receiver. Otherwise the minute signal generated by the phono cartridge is too small for the other inputs to process.
The buzzing noise/bad channel is probably a bad connection in the tonearm/headshell connection or one of the 4 wires attaching the cartridge to the shell. If you DON'T want to blow up your speakers, TURN YOUR RECEIVER OFF, turn the volume to 0 or select another input before messing around with the tonearm.
Swap the two channels from the tonearm to the Phono connectors to prove the buzzing is external (at the turntable). I think the Dual CS415 uses the old standard headshell. With the volume down flip the lever toward the back, carefully remove the assembly and look over the tiny multi-colored wires with the brass crimp-on ends. We're looking for tight kinks or broken wires. Then put it back. maybe reseat it a few times to wear off any oxidation and try it again.
Apr 01, 2009 | Audio Players & Recorders
My stereo receive hums annoyingly when I use my record turntable.
Just a suggestion, make sure the power outlet/s is grounded and that the polarity on both plugs are correct.
Tan Orexic
Mar 12, 2009 | Audio Players & Recorders
Buzzing sound in my speakers when I switch to the phono stage
It is a grounding issue with the turntable most likely. Some turntables came with a ground wire that you attached to the receiver. You can also try a power strip that has a line filter incorporated to get rid of the hum. Check the local stereo shoppe to see if they carry them.
You may also want to replace the audio cable that connects the turntable to the amp with a good quality shielded cable. If it has bad shielding it will pick up electrical interference and even radio interference as well.
Turntable inputs on receivers have a preamp built in and the gain for each type of pickup is different. The pickup is either ceramic or magnetic and if I remember correctly, the ceramic pickup needed more gain than the magnetic one. The preamp will definitely make a ground hum a lot more audible.
Cheers and good luck.
Dec 20, 2008 | RME Intelligent Audio Solutions RME...
How do I connect a turntable
I agree with 'radio head.'
Turntables require a particular frequency response and the input needs to be correctly equalised to accommodate this. If your amp had phono inputs these would be equalised internally.
Unfortunately, many modern amps no longer have phono inputs. There are two possibly three options.
1) You could obtain a turntable that includes built in Phono eq
2) As 'radio head' says, you can obtain in line active equalisers. These are called RIAA Equalisers (Equalizers if you're in the US) or RIAA preamps. This allows you to plug your turntable into a small box, then plug the box into one of the audio inputs on the back of your amp.
3) You may be able to adjust your mixer to the required frequency response and use it as a preamp.
What you cannot do, regrettably, is just plug your turntable into an ordinary audio input. It will not do any harm if you want to try it and it will make a noise, but you won't like it!
Feb 04, 2008 | Harman Kardon AVR 100
Project PHONO BOX Mk2 TURNTABLE PREAMPLIFIER Amplifier Logo
24 people viewed this question
Top Project Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Project Audio Player and Recorder Expert? Answer questions, earn points and help others
