IMac wont start - Computers & Internet
  • Kyle Lerner
    Kyle Lerner Jun 06, 2014
    Hi abil2002, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
My iMac froze and won't reboot
Your question is incomplete. Your imac froze and wont reboot. What you see on screen when you start it? Do you see a spining wheel or a folder sign with a question mark or a blue screen? If yes then it's either corrupt/damaged osx or bad hard drive.
Good luck.
Tech from http://www.computerstar.ca/Macbook_repair_toronto.html
Apr 10, 2013 | Apple iMac Computers & Internet
Imac wont boot from disk
You need to press the Option key while you start your iMac in order to get it to give you the choice of booting from a disk.
Feb 14, 2012 | Computers & Internet
Wont startup.flashing ?
Hi. The Flashing ? means that the mac cannot find a valid start-up drive. Sometimes this can mean a failed Hard-drive but more commonly it is a sign of directory corruption.
It's quite possible with an iMac of this age that you could have a failed Hard-drive. However, if you can locate a copy of DiskWarrior you can fix a corrupt directory.
Feb 05, 2012 | Apple iMac G3 15" M5521 Desktop
IMac OS 9.2 hangs up in the "starting up" mode and
You may have a problem with your internal hard drive.
If you have your original software disks, you can boot the computer from them and run Disk Tools to analyze and possibly correct any problems.
Mar 01, 2011 | Apple Mac OS 8.5 (APPLEOS85)
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Imac wont start no chime black screen
Go to apples support site and look for troubleshooting this issue. There are huge writeups on the imacs.
May 09, 2010 | Apple iMac Z0CY Desktop
My imac wont turn on!
It sounds like something is either corrupted on your system or one of the files in your imac may be suspect. What I would suggest is get your system disc boot the imac down holding down the c key on your keyboard. Once it is booted up go to the file menu and find the disk utility. Open up the disk utility and first of all repair your disk permissions and then run disk verify and if an error comes up choose to repair it.
If this does not work. I would suggest installing a clean system. Again with the system disk in your computer restart your machine with the c key held down on your keyboard. Choose to do an install but remember to select preserve users. This will give you a clean instal with your files and preferences intact.
Once your machine has restarted it is well worth setting a second account under system preferences under accounts as if one account becomes corrupt in the future you have a second account to fall back on.
For prevention of any problems in the future I would download Onyx from this website http://www.switchingtomac.com/tutorials/keep-your-mac-running-smoothly-with-onyx/ which also talks you through the method of using it. I use it every month just to keep my mac in tip top condition.
Hope this helps.
Apr 03, 2010 | Apple 24" iMac Desktop
I did something to the OS on my iMac 9.1 and now it wont wont start up or boot.
do you have the original disk, you can reinstall the software.
or you can do an upgrade to a more recent version of mac OS like 10.5
will your mac handle the upgrade?
give me some specs i will find something you can upgrade to.
might as well
Jun 07, 2009 | Apple iMac OS 9.1
Computers & Internet Logo
David Payne
David Payne
