Question about SanDisk Sansa e260 MP3 Player
Right channel now working.
One of the connectors from the phone jack has pulled away from the mothboard. Anyway to fix this? Can I just get another main board?
  • 8,596 Answers
Wrong section, dude
Posted on May 23, 2008
How to change the jack with new one??
Cut down the old jack.
Remove the cup from the new jack and pull up to the on the cable.
Clean up the wire about 1 cm long. There should be 1 common ground, one for Left and one for right channel.
Solder the Left channel's wire to the inner point.
Solder the Right channel to the middle point .
If you have two independent ground just spin together and solder them to the end point of the jack.
With plier press together the jack end, thi swill hold the wire
Pull down and twist the cap.
Feb 10, 2015 | Juster Vintage Active 95a Multimedia...
Problems getting sound to both channels
Try this see figure to get the idea...
How was it?
FIXYA me on this one... THANKS
Feb 06, 2008 | Olympus VN-3100PC Digital Voice Recorder
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Pioneer A110 Amplifier - quiet right channel.
    > squirt some contact cleaner into it
    An appropriate suggestion with one caution; look for a statement on the cleaner label that it will not harm plastics. I have seen some plastics not dissolve, but crack and disintegrate, along mold lines in particular. If you find no such statement use very sparingly and try to prevent over-spray.
    Feb 24, 2010 | Audio Players & Recorders
    Problems with int 5.1-Channel Home Theater Speaker System
    yes u will need to chandge input jack from mono to stero radio shack $4 part u need y headphone splitter this should fix ur problem
    Aug 07, 2009 | JBL 5.1-Channel Home Theater Speaker...
    Only one earphone works, weird problem
    there is a broken solder joint where it is on the pc board.it is not the earbud itself,because when you pull it out,both sides work.the jack has 3 sections,the tip which is one side,the next piece,which is the other side,and the shank piece which is the ground.the ground connects to the outside ring of the headphone jack.there are 2 contact points inside for the two channels.what happens is the copper foil of the pc board fractures where the pins are soldered.scrape away some of the foil so that copper is exposed for the pins,and resolder it and it will work if you wiggle the jack,you will see the whole piece of circuit board move where it is cracked.after fixing it,put epoxy over the area to make it stronger.
    Jul 19, 2009 | Audio Players & Recorders
    No stereo signal out from yamaha p 2500 s
    It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
    This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
    Did you try the Right one in the Left Channel to see if the Left Channel worked?
    Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
    http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
    STEREO/PARALLEL/BRIDGE switch
    Use this switch to select the operating mode.
    • STEREO mode
    Channels A and B operate independently (as with a conventional
    stereo amplifier). The Channel A input goes to the Channel
    A output jacks, and the Channel B input goes to the
    Channel B output jacks.
    • PARALLEL mode
    The Channel A input signal is output through both the Channel
    A and Channel B output jacks. The Channel B input jacks do
    not function. Channel A and B volumes can be independently
    adjusted.
    • BRIDGE mode
    The Channel A input signal is output from the BRIDGE output
    jacks. To adjust the volume, you must use the Channel A volume
    control knob.
    Apr 03, 2009 | Yamaha P-2500 Amplifier
    LOW VOLUME FROM RIGHT CHANNEL OF STEREO 1 SIDE OF SYSTEM
    It seems like the speaker jack tip needs cleaning, or the contact has become bent away from the connector and needs to be re-aligned.  The Passport is a portable system, so after years of plugging and unplugging the speaker jacks may be worn.  Try using the "Stereo 2" connectors. You can also try cleaning the jack with electrical contact cleaner, and. a cotton swab.
    Jan 07, 2009 | Fender Passport Deluxe 500watt Sound...
    Right channel doesn't work
    check you rca jacks switch sides if the right channel still has no sound then it needs repair if the left channel doesnt work then the rca jacks are messed up
    Mar 26, 2008 | Pyle 3000 Watts 2 Channel High Power...
    30gb ipod
    More than likely the ear bud or the wiring is damaged. Try set from a friend that you know works for confirmation.
    Nov 27, 2007 | Apple iPod MA446LL/A MP3 Player
    SanDisk Sansa e260 MP3 Player Logo
    24 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Mohamed Ismail
    Mohamed Ismail
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
