Phonic mm1002 I have a laptop that i want to connect to a Phonic MM 1002a Mixer to a Peavy M - 2600 Mark V series sterio power amp (amp has 1/4" outlets out of the back of unit) what cables do i need to set this up please?
    Top Expert:
  • Computers & ... Master
  • 21,350 Answers
You need a 3.5mm stereo jack to twin 1/4" jack plugs. That will get audio from your laptop to the mixer. Then, being Peavey, probably a pair or jack to jack 1/4" screened leads for signal from mixer to amp. Then loudspeaker leads to suit your amp and speakers.
Posted on Jan 02, 2014
2 Suggested Answers
Davethesnake
  • 689 Answers
SOURCE: how do i connect Phonic
you should have two or more jack plug sockets,//headphones//mic look for symbols next to sockets
Posted on Sep 05, 2010
How to connect speakers to phonic mr3243 mixer
You would connect the xlr left and right outputs to a power amplifier and then the speakers to the power amp. The mixer will not drive a set of speakers by itself.
Jan 19, 2015 | Phonic Music
I have connected a laptop to a Phonic MM 1002a mixer, Do you need to use both Channel A & B on Peavey M - 2600 Mark V Stereo Am
This depends on what you are trying to do. If you want a mono output from the amp switch it to mono mode and go into one input on the amp, this will mean the amp only works mono.
If your source is stereo you will need to use two inputs on the mixer and pan them both to the side you will be sending to the amp. This will cost you two mono inputs on the mixer though.
If you have anything stereo this is the route you will need to take but I don't see why you would want to do this as surely you'd be better running everything stereo (two channel) and panning any mono signals where you want them and leaving stereo as stereo.
Jan 02, 2014 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
How do i connect Phonic MM1002 mixer, Audio-technica AT3035 microphone, and laptop?
Sep 05, 2010 | Computers & Internet
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Manual
Hi - You can download the manual from the link underlined in blue below:
Phonic MM 1002
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 20, 2008 | Phonic - XP 5000 - 5000 Watt Power...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
