Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Western Digital Elements HD doing a clicking noise and no access
Well i have a Western Digital Elements 500GB, it has 2 years or more it always worked fine to me till today, i always worked with it connected to my computer. Today when i started my computer it was really slow starting windows up and i noticed my Elements HD doing a clicking noise over and over again, and windows can't recognise it, well at least i cant access it with explorer but i can safely remove hardware and it has the information of the HD normal as if it was ok. Any help?
  • marco_arjane May 21, 2009
    Well i believe it is not a power adapter problem because it keeps flashing the blue light, but it is just flashing, turns on, turns off and keeps like that while the drive makes the click sound. BUT i still feel the drive spinning. :S
    President:
  • 2,992 Answers
It might be the power adapter. I had one of these and two Maxtor external drives that just clicked that way and it turned out their adapters were bad. You can check with another adapter if you can borrow one from another drive, or use a replacement from Radio Shack. Make sure you get the same voltage and current rating marked on the original.
If the adapter isn't at fault, the small circuit board in the enclosure may be the trouble. You can remove the drive from the case and connect it to directly to a computer power supply to see if spins up properly.
If the drive still doesn't spin, it's bad. This is a common way for a drive to fail. Unfortunately, this leaves you with a drive that you can't read. Hopefully you've backed your important data up on CD or DVD.
Posted on May 21, 2009
  • May 22, 2009
    A bad power adapter doesn't necessarily mean a dead adapter. The three units I worked on all lit up but the adapter was still the trouble. They all worked just fine once I stuck new adapters on them. The only way to know for sure is to check the drive with a power supply you know is good.
Is this a plug and play drive?
In most computers that are encountered, devices that are plugged into the USB ports are "plug & play" capable. There are numerous scenarios that can turn this function off inadvertantly such as a virus, data corruption or driver changes. In order to fix the issue and make an external device, such as a Western Digital Passport Elite hard drive "plug & play" capable, a user will have to make a few system changes. Click "Start" and "Run," then type gpedit.msc Click on "Administrative Templates," from the tree then click on the "System" folder. Double click on "Turn off Autoplay." Select the "Disabled" option and ensure it applies to all drives. Hope this helps,
Dec 12, 2012 | Western Digital 500GB ELEMENTS 500 GB USB...
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
Whats the input and output for a a power adapter needed to work a wd elements 500gb external hard drive?
Check the label affixed on the unit. It should indicate the power requirements. If not, go to the Western Digital website and locate the specifications for this particular model.
Oct 28, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
I have a Western Digital Elements 500gb it has a 5pin power surply that is no longer working this unite is not even a year old and i can even find a new one for it
Contact Western Digital. The unit should still be under warranty so they should replace the defective power supply for you. Hope this helps.
Sep 15, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Replacement power cables
Can find them on eBay, if you can narrow down on the manufacture date. For the model I had, either Acbel AD6008 OR Asian Power Devices (APD) DA-30C01 work. I ordered a replacement which worked - but my real problem was needing a new hard drive casing. So now I have 2 power cords I don't need...but at least I have my data.
Jan 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Western digital 500 not coming on
did you drop it anytime recently...
if you did ....there is a possiblity of damaging the cylinders and sectors inside which could make it difficult to retrieve the data stored in the hd...
please take it to a service center to find it is not the case...
or
try to connect your hd in another system and see whether it works in that system
thankyou
Aug 31, 2008 | Western Digital 500GB My Book World...
External Hard drives
I will recommend you to use Western Digital I my self alos using a western Digital and its very reliable to use , So I will go for buying that one and it will be a big help for you...
Hope that helps.......
Aug 18, 2008 | Computers & Internet
Mybook of 500GB has a strange noise in disk
If it's making a clicking, rattling, or "leaking" (like the sound of air whistling out of a balloon) then the drive may be damaged and it's time to contact Western Digital support.
May 21, 2008 | Western Digital 320GB MyBook External USB...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
1,473 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
