Question about Bosch HMV9305 Microwave Oven
Outside venting of Bosch Microwave HMV9305
I need the damper/duct connector for the above stated Bosch Microwave. Do you carry this part?
Thank you,
Walter Guptill
5 Suggested Answers
SOURCE: vent fan runs intermittently, starts on and off regularily
I read in a different online review that whenever a room is above 70 the vent fan will start automatically for this microwave to cool it down. It is a built in feature and there is no way to turn it off.
Posted on Dec 10, 2007
tiway1
  • 100 Answers
SOURCE: fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Posted on Dec 23, 2008
  • 8909 Answers
SOURCE: I have a Bosch Microwave,
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on eventhough the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Posted on Dec 30, 2010
  • 9 Answers
SOURCE: hmv9305/01 microwave @ 13months old
Microwave oven usualy brake magnetron cost putting foil,metal inside ... or not good installation of new magnetron before install new magnetron need to clean housing of magnetron , take off all carbon got from old magtube
Posted on May 27, 2011
Galaxy microwave model 85100
If your microwave is ducted to the exterior the cold air could be from the outside if the backdaft damper is not functioning properly. If you have a HVAC system, the return air process can be pulling outside air through the hood making the condition worse. The microwave damper is usually on top of the microwave unit at the exhuast opening. Maybe some greasy dust is preventing the damper from closing all the way.
Nov 30, 2013 | Microwave Ovens
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
How does this microwave exhaust system work. The installer did not use any duct work, so is the exhaust internal somehow? There is no grill on the exterior for exhaust
The exhaust fan appears to intake through a louvered vent in the bottom rear of the microwave case and output through a grease filter near the top front center of the case. You may be able to see some vent holes along the top of the case though these might be obscured by the manner in which the microwave was installed. You should be able to pop off the front panel that runs above the door but you'll need to consult the owners manual for specific instuctions.
Cheers.
Apr 08, 2011 | Bosch HMV9305 Microwave Oven
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
Microwave vent turned on by itself and won't turn off
The HMV9305 has an automatic vent turn-on feature. It senses heat, possibly from the oven or range beneath, and turns on the exhaust fan until temps return to normal. Sometimes this may take 4-5 minutes, which can seem like an eternity of listening to the blower run, but it is a safety feature designed to prevent damage to the microwave from excessive heat generated by the cooktop or oven beneath it.
Jan 24, 2010 | Bosch HMV9305 Microwave Oven
How to vent outside
are you referring to an over the range microwave with an exhaust fan? It should have come with a damper kit and adapter to go a standard duct size and run it either trough the back wall or straight up
Jun 17, 2009 | Microwave Ovens
Fan just circulates air instead of exhausting the air outside
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
Venting
If this microwave has vented outside in the past then most likely a bird or something has built i nest in or on the vent blocking airflow. If its always been this way then in order for this model to vent though an exterior duct the blower motor has to be flipped so that it blows upwards and a vent connector needs to be installed. This is a fairly easy process once the microwave has been taken down but can be dangerous because there is a capacitor that holds 4000 volts that can discharge though the cabinet if you're not careful.
Nov 03, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
Bosch HMV9305 Microwave Oven Logo
264 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
