Question about Acer Computers & Internet
Desktop keeps refreshing every 5 secs
I try to click any program but it wont open
    Top Expert:
  • Acer Master
  • 26,753 Answers
I would run a registry cleaner and then defrag the drive.
Posted on Jan 02, 2014
Sounds like malware, try rebooting and enter safe mode with networking (repeatedly hitting F8 as soon as it starts rebooting will bring up this menu) . Install ADWcleaner and run through the scan then reboot into normal mode
Jan 02, 2014 | Acer Computers & Internet
My desktop pointer divice will not open anything just keeps trying
Try shutting down ALL unnessary running programs. Use CCLEANER freeware at: http://www.filehippo.com/download_ccleaner/. This will clean the junk from your machine. In the TOOLS section, STARTUP page, disable ALL Unnessary startup programs. Open the Task Manager to see what is using all your memory/processor resourses. Runa Full Scan with MALWAREBYTES freeware : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the PRO TRIAL version, you want the freeware version. Remove ALL unnessary TOOLBARS from your broswer, they are killers on broswer speed.
Jan 05, 2013 | HP Compaq Armada M700 Notebook
Screen only shows windows sign wont go to anything else
Welcome to Fixya
Try to restore the computer from the date where you remember the computer is working fine. Turn off the computer then turn it on after 5 secs. Keep on tapping F8 key then select SAFE MODE. Once you as inside windows safe mode, click start then all programs then accessories then system tools. Click system restore then select a date where you want to restore the computer.
Cheers
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Dec 25, 2011 | Sylvania G-Netbook
How do you program new spare key for 2007 rodeo RA?
if its the ignition key it must be done by a dealer and have a lage black plastic head which has got a transponder in it. If you got a blank key cut at the locksmith it will turn the locks but wont start the car. Usually you get the dealer to do both supply ignition key and then get it cut, then they can program it.
but if your asking how to program the keyless entry remote follow this procedure.
take note step 5 is different for different year models.
Make sure that all the doors are closed and unlocked and wait for dome light to go out before starting.
Insert the ignition key into the ignition switch
Open drivers door
3 on/lock
Close/open drivers door
Wait 8 secs
On/lock/on (MY06-07) OR 2 on/lock OR on/lock (MY08)
Close drivers door
Hazards flash
Press remote & keep pressing one button & then the other slowly(2 secs) until locks start working(they wont operate if key is in ignition).
Hazards flash
Feb 23, 2011 | Isuzu Rodeo Cars & Trucks
The monitor keeps saying 'over range' and halts any programme. what dose over range mean
That error means you've either chosen a resolution or a refresh rate which exceeds your monitor's capabilities.
Select a lower refresh rate, and/or set back to the defaults.
Try booting into Safe Mode by tapping F8 at boot
when you are into the safe mode it will allow you to default your video card ...or ..even insert the driver and reinstall it ..Reinstalling the video driver will allow it to get to the default (optimal) values..
if you can open it in normal mode...and only on certain programs does this ..than you should first ..click right on desktop ..and after that properties..and setting s(usually the last one in the right ) ..in there check the resolution and set a lower value..
Oct 24, 2010 | Computers & Internet
I cant get creatures 2 to work on vista
Many old pc games are not compatible with vista. It may work if you right click on desktop icon click properties then click compatibility and set check the box to "run this program in compatibility mode for xp service pack 2". Hope that helped!!!
Mar 24, 2010 | HP Computers & Internet
Yahoo wont open
First open task manager....check if there is any yahoo messenger service running on services....click that and click End Process and now try run the proggy...again if that also not helps try uninstall the Yahoo messenger ...download and install new version....Good Luck
Sep 25, 2009 | Yahoo Messenger
I've got a dell computer and i'm trying to swap the crt screen to a packard bell lcd screen and it wont display is there a driver i have to get or are they just not compatable
It probably a mismatch between resolution, colour depth and refresh rates. Before you disconnect the CRT change the resolution to 640x480 and 16 colours with a 60Hz refresh. Then connect the LCD and adjust the settings
Aug 29, 2009 | Dell Dimension 4600 PC Desktop
Cant use my usb
Refresh and reinstall USB Ports Of Your Computer Hello there, the other day i tried refreshing and reinstalling the USB ports on my PC, as some of my connecting devices are not recognized. I present the detailed procedure on refreshing the USB ports.
Let’s go!!
Here are the steps to refresh/reinstall/uninstalling the USB ports on the computer.
The USB port needs to be refreshed to make sure that no other device has captured the USB port of the computer. The Mouse, video camera, your external USB hard disk; what ever it may be.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager Button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external USB hard disk...USB hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main USB devices at the rear end USB port. As they require more power to initiate.
The above steps are for XP operating system. When coming to the matter of Vista, please note the changes below:
1) Right-click Computer icon from the desktop , and then click Properties to open the System Properties window, and then select the Device Manager tab.
2) Click the Plus (+) sign next to Universal Serial Bus Controllers/Root hub.
3) Click the USB Composite Device entry to highlight it, and then click Remove. If a screen appears to confirm the deletion, confirm the deletion.
4) Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
5) A New Hardware found screen may appear, click next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 06, 2009 | Toshiba Satellite M35X-S311 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
