Question about Toys
Magnext 29912 anleitung - Toys
Tevion md018
If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 27, 2013 | Televison & Video
The box isn't powering the balls. we don't know if we have a short in the box, or not. 29310 Mega brands magnext icoaster
Hey Chadlock
Here are some possible solutions:
The box might have dead batteries or try seeing if the elevator is hooked up to the box fully.
If you are still having a problem this site has a icoaster instruction link http://www.icoasterkids.com
Hope this helps.
Kids
Dec 25, 2010 | Dmm Mega Brands Magnext iCoaster
The marbles go up the tower just fine, but most of the time they all get backed up at the first magnet. sometimes the 2nd or 3rd marble will hit hard enough to push to first one out, but most of the time...
What I did was spread the first magnet block apart from the track part underneath it slightly. I used my thumbs to bend them a apart a little more. Now each ball gets slowed down but not stopped by the top magnet, I didn't do anything to the down side magnet and the balls pass right through.
Of course just don't use too much strength. It just takes a little more separation.
Dec 22, 2010 | Dmm Mega Brands Magnext iCoaster
ABS and Hand Break problem
operating errors in your ABS modulator. May be an issue with an ABS sensor. Get Vag-Com programme to interact with computer to solve. Or bring to Main dealer as you've got a reduced braking capability right now
Jan 16, 2009 | 2000 Volkswagen Passat 4Motion
Philips fax phone hfc 171
It goes face up into the bottom of the machine. Here's a manual. http://www.fax-anleitung.de/Philips/Fax%20HFC/BDA%20HFC141-171%20uk.pdf
Carl
Nov 10, 2008 | Philips Lands Phones
WinTv-crash
OK Guys - i fixed it. it s a known problem:
------------------------- Absturz von WinTV in Modul ntdll.dll im Sat-Suchlauf Laden Sie ntfix2.exe herunter, führen Sie diese aus und gehen Sie nach folgender Anleitung vor:
Stellen Sie sicher, dass WinTV beendet ist.
Stellen Sie sicher dass der EPG-Dienst beendet ist, falls Sie diesen installiert haben
(rechts unten in der Startleiste, klicken Sie mit der rechten Maustaste auf das blaue Symbol und auf "Exit").
Führen Sie die Datei ntfix.cmd aus.
Die Dateien werden nach C:\Hauppauge\ntfix entpackt.
Falls gemeldet wird, dass 0 Dateien kopiert wurden, starten Sie Ihr Betriebssystem im Abgesicherten Modus (F8 vor dem Start drücken) und führen Sie die Datei ntfix.cmd erneut aus.
Alternativ können Sie die aktualisierte Transponderliste satellites.exe herunterladen, und diese exe-Datei ausführen, um das Problem zu beheben.
it works :-)
Mar 10, 2008 | Hauppauge WinTV-USB-2 [ 1020 ] (120904)
Dell Inspiron 710 M mic problem
I can understand your problem Pooja.
I found a fix for you. Click the link below & scroll down to Models with Windows XP and a Sigmatel STAC97 Audio Chip.
http://www.dellcommunity.com/supportforums/board/message?board.id=insp_audio&message.id=29912
Follow the instruction.
Let me know if this gets things going. There's a whole lot of people out there with the same problem. I just don't have a dell 710 laying around to test this fix.
Good luck Pooja!
Let me know how this goes.....
& please vote.
Mar 10, 2008 | Dell Inspiron 710m Notebook
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
