Question about Water Heaters
Piezo ignition - my gas water heater does not have one where there should be one! What can I do?
  • Water Heaters Master
  • 5,245 Answers
4 Suggested Answers
  • 34 Answers
SOURCE: Water heater with electonic igniter will not work in power outage
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Posted on Feb 08, 2009
  • 21 Answers
SOURCE: Hi Our gas water heater is not igniting
you need to replace the thermocouple its an electronic device that keep the gas flowing . the pilot light is always on and the thermo couple controls the flame. if it goes bad the flame goes out and the burner wont come on to heat the water, they are easy to replace and available at all home depot or a lowes kind of store.
Posted on Dec 03, 2009
motor1258
  • 6674 Answers
SOURCE: the electronic ignition on a gas water heater will
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Posted on Jul 20, 2010
Is there a battery on my water heater
The automatic spark ignition must be powered by something, so it is isn't attached to a mains outlet than it must have a battery pack. The other type of ignition is Piezo and for that you push a button and it clicks as the spark is generated.
Mar 13, 2016 | Water Water Heaters
No spark visible through mica glass inspection cover when piezo igniter button is operated.
Piezo igniters can fail for a few reasons. Often they short or spark in the wrong place. Sometimes they can be corroded. Try cleaning it and see if it will spark. Otherwise, you might need to replace it or just use matches. Is your heater under warranty?
Jun 11, 2015 | Water Heaters
Self igniting hot water heater won't reset.
Today's water heaters have sealed combustion chamber and piezo igniter.
If igniter is bad, then water heater will not light... replace igniter.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Gene h
Mar 31, 2014 | Water Heaters
Bosch aquastar a125b piezo wiring diagram
Piezo igniter only needs 1 wire to cause spark.
The other wire might connect to electronic gas control to report error, but brand type and age of product is not described in question.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene h
Mar 18, 2014 | Water Heaters
Finally found the reset button on my Whirlpool hot water tank, but it will not budge when I push it. Why? Pilot will not light.
Reset button on gas water heater??
Usually there is not a reset button on gas water heater, which might explain why is doesn't move:
Do you mean the igniter button for lighting pilot?? The piezo igniter can go bad.
Copy following links for troubleshoot resources:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add comment with description of water heater, and more detail or call plumber.
Gene
h
Aug 23, 2013 | Water Heaters
Whirpool water heater unable to lit
Whirlpool water heaters are made by American-AOSmith.
Approximate age of water heater is unknown, and type of gas control valve is unknown.
Clean air intake located bottom of heater, using a feather duster.
Get more fresh air to the water heater and see if that solves problem.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
If you have piezo igniter, then check if it is putting off spark.
If there is no gas at the pilot, then gas control valve is probably bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
If pilot will light but not stay lit, then change thermocouple.
Watch videos on utube to lean how to replace thermocouple.
For pilot light problems: Read information on following link:
Jul 27, 2012 | Water Heaters
Just purchast and installed everything hooked up push the sparker looking through window I see nothing
You posted under Reliance gas water heater
You installed a new gas water heater and are trying to light water heater using the piezo igniter.
Not clear is what steps you have taken so far, and which gas control valve is on the new water heater, and what lighting instructions say on side of water heater.
Also unknown if you bled air out of gas line, or if gas shut-off handle is rotated so handle is parallel with gas line.
Read instructions written on side of tank, open link below to double-check installation, and then add a comment with steps you have taken so far, and describe the type of gas control valve on water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 03, 2011 | Reliance Natural Gas Water Heater Control
Why won't my pilot light? It has been connected and has gas. It is Piezo-electric.
There could be air in the gas line..just follow the instruction on the unit these unit always never give any trouble to ignite.. if you still having problem get a qualified technician to light it..
Jul 03, 2010 | Rheem Water Heaters
Ihave a new water heater.Worked for 3 days.Now back to Ice baths
All new tank-type gas water heaters for the home are designed with Flammable Vapor Ignition Resistant systems. It sounds like the unit has shut down because of a venting problem. If it is a Rheem or Ruud (General Electric for Home Depot) you have to reploace the heater. Other brands alow for resetting this safety device. Don't take chances with gas if you are not absolutely sure of what you are doing - have a professional licensed plumber check out the problem.
Jun 04, 2009 | Water Heaters
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
