Question about Bosch Dishwashers
Bosch skt5102 No warm water
2 Suggested Answers
SOURCE: Bosch SKT5102/GB - The cycle
It could also be the microswitches on the pressure chamber.
Posted on Aug 04, 2011
Luke warm water
is the water temperature dial turned up? or even functioning?
Jul 28, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
No water filling the dishwasher.
The circulation pump is possibly leaking and has activated the flood safety, if you can get the unit near a sink and tip it you may find water coming out from the frame area. I would suggest if this is the case that you contact an expert such as BSH home appliances as these units can be quite tricky to work on if you don't have any experience.
Hope this helps.
Jul 09, 2010 | Bosch 22 in. SKT5102 Free-Standing...
SKT5102/gb1 - not pumping out
I had a problem that seems to be related, but it came out that the pump was blocked. I had service to open and remove a small plastic clip that had came into the machine accidently. I do not recognize that water was pumped back as you explain but if the water is not emptied may be this is the result...
Jul 24, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Bosch SKT5102/GB - The cycle is not producing any water into the dishwasher. Have tried the filter and ensured that the water is on.
I had the same problem..inletvalve broken.costed me 11 euro to fix it.partnr in holland is:857950
Jul 07, 2008 | Bosch Dishwashers
Bosch SKT5102
It sounds like the switch but you don't need the bosch one if it is only the micro-switch they are easily available
ger531
Jan 09, 2008 | Bosch 22 in. SKT5002GB Built-In Dishwasher
Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Jan 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Dishwasher wont progress to next step
Does after the manual moving to the next step, the dishwasher complete the cleaning process properly ?
May 16, 2007 | Bosch 22 in. SKT5102 Free-Standing...
Dishwashers Logo
18 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
