Question about Samsung T24b300 23.6 Inch Widescreen Led Tv/Monitor With Digital Tv Tuner - Gloss Black Full 1080P, Dolby Digital , Hdmi, Vga, Usb, Scart
Standby light too bright
Turn off the tv and a blue/white standby light comes on lighting up the whole bedroom- how do I turn this off???
  • 191 Answers
SOURCE: SAMSUNG TV
your tv inverter is bad
Posted on Nov 02, 2008
Axle80
  • 73 Answers
SOURCE: How do you turn off light at bottom of TV under Samsung name?
black electrical tape. Ha ha. There is a way to turn the standby light off in the menu on certain sammy TVs. I don't know if yours is one of those. And for the record, don't ever ever buy a tv in the UK, they burn down houses.... HA HA.
Posted on Jun 13, 2009
SOURCE: TV wants to turn on & off (clicking sound)for about 10 minutes.
I had the exact same problem on my LN-T5265F LCD (clicking on and off - stays on after 10 minutes). I just followed the advice here. - I opened up the TV (very easy 20 or so screws).
- Took the cover off the BN44-10150A power board.
- Found the two bad capacitors on the top right of the board. (They were bulged on the top)
- Went to Radio Shack and purchased two 1000uf capacitors
- De-soldered the old caps and soldered in the new ones
- Screwed the TV back together
- Powered it on and it is working great now!
Thanks to everyone who posted here. A repair that could have been a several hundred dollars with a service call, turned out to be a $6.00 fix by replacing a couple of capacitors myself. The wife thinks I’m a genius. Funny thing – I told the guy at the Radio Shack what I was doing and he said “why don’t you just get a new TV, They’re very inexpensive now”.
Posted on Sep 06, 2009
budmrtn
  • 11361 Answers
SOURCE: When you turn it on it takes 30 minutes to come
You have dying power supply more likely due to bad caps, that is what you should look for, do not keep trying to use the TV or maore damage may result due to unstable DC voltages with a lot of AC ripples feeding the circuits.
Look for caps with leaking/bulging tops/bottom seals.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find
Posted on Dec 01, 2010
spr1949
  • 1182 Answers
SOURCE: Samsung FlatPanel has picture for a minute or so then turns white/light blue
Is there same problem with other input devices also? Look for any jammed buttons on the remote. If it does not work even then, this may need attention by a qualified service technician.
Posted on Jul 28, 2012
When I turn off my Luxor TV in the bedroom the standby light flashes blue then orange. The lights are very bright & I have to get out of bed to switch off at the wall socket. What is the problem and...
The alternating blue orange light means you have put a reminder on for a program that hasnt started before you switched off, you need to remove the reminder before you turn the tv off then the light will be steady blue
Sep 14, 2011 | Audio Players & Recorders
Tip
Increase Your TV's Lifespan
Considering the whole goal of television salesmen is to have us return to buy more televisions when the old ones give out, perhaps we shouldn't trust the settings they provide by default. By fiddling a bit with your TV's settings,you can:
Increase Your Set's Lifespan: TVs are a lot like bonfires: the brighter they burn, the faster they fade. Turning down your TV's contrast control can greatly increase the life span of the tube, the plasma panel, or the bulb that produces your TV's light.
Reduce Headaches: Ever watch a small bright television in the bedroom with no other lights on? Ever wake up with a headache? The two may be connected, and reducing the brightness of the television can save you money on aspirin.
on Dec 18, 2009 | Televison & Video
The power light (bright blue) on my Olevia 26" LCD burns brightly in my bedroom ALL DAY and ALL NIGHT. Is there anyway to dim it?
Had the same problem and took the easy way out: I cut a small piece of electrical tape and covered the LED. There is no way to dim it.
Dec 23, 2009 | Olevia LT27HVX 27 in. LCD Television
Samsung 933HD TV and the blue light comes on when the TV is off
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Dec 15, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Hi I am Vortash that is the standby light and the only way to turn it out is to turn the set off at the wall ? This is the safest thing to do at night in any case Televisions are responsible for more fires in the home than almost anything else .
Here in the United Kingdom there was even a Public announcement film made just to tell people to unplug them at night made by the Fire safety council ... regards Vortash
May 29, 2009 | Samsung LN32A550 32 in. LCD TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Blue light on.
Take back off of tv and unplug the connector marked CN1
Apr 26, 2008 | Olevia LT32HVM 32 in. LCD Television
I am getting 5 blinks
If the whole screen turns a bright blue and shuts down then you may have a bad blue crt. This will need to be replaced plus adjustments/alignments. Get an authorized Sony servicer to do the repair. Good Luck
Jan 09, 2008 | Sony KP-65WS500 65" Rear Projection...
Samsung T24b300 23.6 Inch Widescreen Led Tv/Monitor With Digital Tv Tuner - Gloss Black Full 1080P, Dolby Digital , Hdmi, Vga, Usb, Scart Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
