Question about Apple MacBook Pro with 17" Display
Video issue macbookpro 2006
After startup and regular sound White screen appears and doesn't go away. Pram and smc have been reset multiple times.
  • 191 Answers
Startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Posted on Jan 05, 2014
Macbook - lost left speaker, data, and camera. SMC reset either way didn't fix. Running external monitor which does work
You may have to reset the PRAM. Note: To print these instructions, open Help Viewer's Action pop-up menu (looks like a gear), then choose Print.
  1. Shut down your Mac.
  2. Locate the following keys on the keyboard: Option, Command (?), P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on your Mac.
  4. Immediately press and hold the Option-Command-P-R keys. You must press this key combination before the gray screen appears. Continue holding the keys down until your Mac restarts, and you hear the startup sound for the second time.
  5. Release the keys.
Resetting PRAM may change some system settings and preferences. Use System Preferences to restore your settings.
Happy 2015!
May 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Locked
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Feb 23, 2014 | Apple Air Computers & Internet
World icon with exclamation mark in the center macbook
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 27, 2014 | Apple Computers & Internet
Restart appears on start up
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 26, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Lion os mute button checked
Did you try resetting the PRAM and SMC?
Resetting PRAM and NVRAM
1. Shut down the computer (by holding the power button).
2. Turn on the computer. Wait until I hear the boot sound.
3. Press and hold the Command-Option-P-R keys (simultenously).
4. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
Reset the SMC
When the above 5 steps didn't prove to of much help you can try resetting the SMC.
Close the Mac.
Detach any peripherals, cables, power wires, battery etc.
Be patient for several minutes.
Re-attach all the cables, peripherals like before.
Now turn ON the OS X
Sep 25, 2012 | Apple Computers & Internet
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
IMac 10.4.11 all of a sudden only boots in safe mode
try resetting the SMC and the NVRAM. This occasionally stores the startup state and any keystrokes used during boot. Common issue with all intel macs. Resetting PRAM and NVRAM 1. Shut down the computer. 2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4. 3. Turn on the computer. 4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears. 5. Hold the keys down until the computer restarts and you hear the startup sound for the second time. 6. Release the keys. Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models. To reset the SMC on an iMac 1. From the Apple menu, choose Shut Down (or if the computer is not responding, hold the power button for approximately ten seconds until it powers off). 2. Unplug all cables from the computer, including the power cord. 3. Wait at least 15 seconds. The SMC reset occurs automatically once the iMac has been unplugged from the AC power source for several seconds. 4. Plug the power cord back in, making sure the power button is not being pressed at the time. 5. Reconnect your keyboard and mouse to the computer. 6. Press the power button on the back to start up your computer. Note: The iMac does not have a button on the main logic board for resetting the SMC, which eliminates the need to remove the computer?s cover to reset it (as required for some other models).
Jun 10, 2009 | Apple Mac OS X 10.4
Apple MacBook Pro with 17" Display Logo
91 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
