Question about Zanussi FLE1416W Front Load Washer
Start/Pause light flashing but machine won't start
Hi, When i switch my machine on and change it to the correct wash cycle the start/pause button just flashes and nothing happens when i press it. I've looked on several forums for a solution and have found out how to get the error "code" (switching machine off, holding down start and reset while switching machine on then setting it to 40 degrees) and the 2nd (wash), 4th (rinse hold) and 8th (end) lights come on. Unfortunately i can't find out what this definitely means, even when looking in the manual. From what i can gather it might be to do with water drainage problems but i'm not certain. Any ideas?
2 Suggested Answers
  • 139 Answers
SOURCE: Zanussi FJ1254 W - Machine does not fill
Yes if you remove your soap draw and take a look inside you will see that there is all residue built on the top part of the internal draw, Either you can jet wash it off or replace the soap draw,,
this should solve your problem.. if that does not work then one of your solinoid valves at the back is faulty...
Posted on Dec 02, 2007
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
Unplug machine and wait a few minutes and replug it in again! This usually resets the computer on the washer but be prepared if it happens on a regular basis you may need to call a qualified repairman that can troubleshoot the problem!
Jan 02, 2014 | Zanussi FLE1416W Front Load Washer
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Machine won't restart after reset, 'start/pause' button flashing.
When you put it to drain/spin does the pump make any attempt to drain,if not it could be that there is something stuck in the pump,needs draining manually.Another thing to try is to find the fault code.If you hold down the 2 buttons on the far right of panel then press on/off button till lights start chasing,then release the 2 buttons on right hand side.Now the first function button by the on/off button you will need to press until the light above the button reaches the 9th or 10th position this will give you a read out in the display.
E10 = low water press.
E20 = pump or filter.
E30 = press. switch or heater faults.
E40 = Door swich.
E50 = motor.
Some of these numbers can vary there are more but those are the most common.After checking codes switch off machine then back on twice to reset.
Hope this helps.
Jan 26, 2010 | Zanussi FLE1416W Front Load Washer
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Zanussi FLE1416W Front Load Washer Logo
15 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
