Calculate acceleration - Office Equipment & Supplies
Formula for calculating acceleration
Acceleration is the change in velocity divided by time. See Acceleration Wikipedia
Nov 10, 2016 | Miscellaneous
It will not accelerate. I push on the gas and it won't go. I changed the oil a week ago and about a year ago i changed the fuel pump
Well an oil change is probably not the cause.
What IS it doing? You're telling me what it isn't doing...
Does the motor rev up?
Jun 10, 2015 | 2002 Chevrolet Tahoe
Engine power loss message
You need to have it checked for DTC'S - diagnostic trouble codes , There is a problem with throttle actuator control (TAC) - electronic throttle control !
Throttle Actuator Control (TAC) Overview
The throttle actuator control (TAC) system uses vehicle electronics and components to calculate and control the position of the throttle blade. This eliminates the need for a mechanical cable attachment from the accelerator pedal to the throttle body. This system also performs the cruise control functions as well.
The TAC system components include, but are not limited to the following:
The accelerator pedal position (APP) sensors
The throttle body
The powertrain control module (PCM)
Each of these components interface together to ensure accurate calculations and control of the throttle position (TP).
Drive by Wire Function and Diagnostics by Wells
Mar 29, 2015 | Cars & Trucks
Why does my 2000 camaro 3.8 have a random surge during acceleration when the Asr is turned on?
ASR is your traction control, the reason why you have a surge is that the ASR is calculating how much force to give to each tire based on sensor data, and this takes time. When you turn it off, the acceleration is treated like any other car with out traction control. The 2000-2003 Camaro had one big complaint, a laggy traction control. You could potentially fix this by replacing the computer unit with a faster aftermarket model and changing sensors out with more efficient models, also tuning the engine can help reduce lag time or acceleration delay.
Jan 28, 2015 | 2000 Chevrolet Camaro
The spindle of a mixer rotating at 1500rad/min slows down uniformly to 700rad/min while making 40revolution,. Calculate the angular acceleration
Use the equation linking the final angular velocity and the initial angular velocity
(omega_final)^2=(omega_initial)^2+2alpha(theta_ final -theta_initial)
Each revolution is 2PI radians.
Dec 26, 2014 | Office Equipment & Supplies
How to calculate coefficient of variation on TI-36XPro
As given in part three of the question, divide the standard deviation by the average then multiply by 100.
Sep 20, 2014 | Texas Instruments TEXTI36XPRO TEXAS...
If a car went from 0 to 100 km/h in 3.7 seconds, using the accelerationn formula how would I find the average acceleration?
Convert the speed from km / h to m/s.
Change in speed = (Final speed (in m/s) - initial speed (0))/ 3.7 s
The result is the average acceleration in m / s^2.
100 km /h = (100 000 m)/ (3600 s)= 27.7778 m/s
May 27, 2014 | Texas Instruments TI-30 XIIS Calculator
An object undergoes free fall for 126m on a fictitious planet (Whoosedat) It takes 6.00s to travel 126m. What is the acceleration of gravity on Whoosedat?
For any free-falling object, the distance traveled by that object can be represented as:
s = 1/2 g t2
where
s = distance traveled by the object, g = gravity, t = time
So, if we resolve for g, we get:
g = (2 x s) / t2
So, by replacing the known values we get the acceleration of gravity for that planet:
g = 7 m/s2
Sep 17, 2013 | Office Equipment & Supplies
Calculate the acceleration of gravity on the surface of Mars, give the mass of Mars = .11mass of Earth, and the radius of Mars = .53radius of Earth.
Let g_e the acceleration of gravity at the surface of the Earth, M_e the mass of the Earth, and R_e the radius of the Earth
For Mars, we have g_m, M_m, and R_m.
g_e=G*M_e/(R_e)^2
g_m=G*M_m/(R_m)2
g_m/g_e=(M_m/M_e)*(R_e/R_m)^2=(0.11)(1/0.53)^2=0.11/(0.53)^2
g_m=0.11*g_e/(0.53)^2
Feb 19, 2012 | Office Equipment & Supplies
15 people viewed this question
jasbo
jasbo
