Question about Sony PlayStation 2 (PS2) Console
BLACK SCREEN ON STARTUP
WHEN I START UP MY PS 2 ALL THE BUTTONS SHOW UP BUT THE TV SCREEN IS BLACK
Netflix has 25 percent black screen at the top!!!
Your screen resolution is incorrect for the resolution of the Netflix stream, try changing the size settings on your TV. (If your TV is not a modern flat screen it will be over scanned )
May 12, 2014 | Netflix
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
My ps2 on start up show a flickering black and white screen that you cannot read and will not play a game but it will play a brand new game out of the box once you get past the black and white flickering...
Ok are you sure it is set to the TV's & PS/2's Video Format, it is either PAL, or NTSC? Check that. ON BOTH TV & PS/2 and it must be same on both. Or AUTO. just a thought.
Jun 06, 2010 | Sony PlayStation 2 (PS2) Console
Menu screen is black
That sounds like your video card is going out on your computer. You will have to get that replaced and then things will work properly.
Jun 10, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
I have a compaq laptop and a samsung lcd tv i tryed to connect using a vga and after startup screen on tv goes black but moniter on the laptop works fine any help would be appreciated
You would have to allow the laptop to use the tv as a external monitor. simply right click on your desktop click properties in their just have a look around and it will show 2 monitors allow the tv as one
Hope this helped
-Ryan
-Please Vote if this helped.
Feb 18, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Black Lines
Just to reset first before proceed another procedure;
Resetting the TV
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet for 4 - 6 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards,
VOTIT
Oct 07, 2008 | Hitachi 61SWX10B 61" Rear Projection...
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Startup problem
This could be a corrupt bios or a low cmos battery, follow instructions. Take the right hand side panel off the pc. Look for a disc shaped 3V watch type battery and replace (Very cheap) Look on the motherboard and reset the bios at the 'JBAT1' terminal put jumper(little plastic cap) from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. Restart pc and enter bios when prompted(or press F2 or DEL on startup) to set time and date, save settings and Exit bios. It should now boot ok.
Jan 25, 2007 | Systemax AOL Optimized PC (100607) PC...
Sony PlayStation 2 (PS2) Console Logo
116 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
