Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Water drains into fruit bin. not drain hole.There is no blockage in drain hole that I can see.F/F Liebherr premium model
  • GE Master
  • 19,396 Answers
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Posted on May 21, 2009
Model RF217ACPN water in the vegetable bins and below bins
I am pretty sure you are having a defrost by CouponDropDown">drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Mar 31, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My upright freezer has collected water in the bottom and froze. What caused this and how to fix it?
Defrost cycle causes it. It comes from humidity in the air. You might have a blocked drain line. Try defrosting the unit for 24 hours and clearing the blockage in the back. There should be a half inch hole for water to drain out.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 23, 2011 | Whirlpool Upright Freezer EV201NZR
We appear to have a blockage in the pipe that takes liquid from the fride part of our FFSS70 model. Because of this we get water forming in the bottom of the fridge each day.We have tried all ways to try...
Hi Bob. First off let me say that a clogged compartment drain with ice in it can be a real pain. Portable hair dryers don't work because the water insulates the ice. You may not like the answer here but this is several decades of hands on exerience speaking. So here goes......
1. Unplug the unit.
2. Empty the contents of the freezer
3. Place a fan blowing into the freezer section for well over 2 hours.
(THIS MAKES A MESS so be ready with rags and a mop)
<After external fan period and mess period>
4. Get yourself a single strand of #14 gage household electrical wire with insulation. Strip the end of the wire about 1 inch on the very end of the wire, fold it back on itself so that there is not a sharp end. (Flat tight U Loop) and start pushing it through the drain. If you hit any blockages or elbows try bending the loop just slightly. (Just do not force it really hard as you may detach the drain tube from the freezer compartment. Measure the distance that you have traveled the wire through the drain. It is pretty much a straight shot top to under the bottom of the chassis at which point there are some bends. Once you know you have reached the bottom of the chassis... pour HOT water thru the drain and observe the lower catch tray in the bottom of the unit checking for water flow from the tube. Often the plastic tray in the bottom of the unit has water in it just as a result of normal defrosting. The end of the cabinet drain tube sits in that tray. Over time the dust and lint that collects forms an ugly goo in the plastic tray. That goo eventually dries out and can also encapsulate the end of the drain tube. Make sure to clean the drain pain and the end of the drain tube during this process.
If you have problems and there is water in the drain that you need to remove; a roast baster works pretty good for removal of the water near the drain.
While you have it manually defrosted do your best to clean the drain top and bottom. These 2 areas are where most blockages occur.
Once your all done cleaning... wipe the bottom catch tray dry.
Pour a measure amount of water 50 ml or so in the top drain.
Check to make sure you get 50 ml at the catch tray. If you do not get close to what you put in.. at least 45 ml. Then there is a problem with the drain tube. i.e Hole, pinch, fold etc.
Getting the unit to room temp... (Fan) and letting the room temp defrost the ice in the tube is the best way to clear this. Slow process but a must do. There really is not a fast way to do this. If you don't have access to a piece of wire... a larger LONG plastic ZIP / Cable / Spot tie (Like they use for handcuffs) will work well also.
Just a final note. I looked up your unit parts via Hotpoint UK.
http://www.hotpoint.co.uk/hotpoint (Model FFS70S)
There are 116 parts available and the drain is not listed.... be careful.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Hotpoint Freezers
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
My freezer is over freezing and my fridge is undercooling. there is also water collecting on the top shelve of my fridge.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 06, 2009 | Kenmore Freezers
Frigidaire side by side: water fills up in bottom of freezer
You have a blockage in your drain tube, at the bottom of the metal tray there is a hole which is connected to a tube which runs down the back of your refridge to a pan next to the compressor. It is an easy fix have done this 1000's times. Remove back panel in freezer, grab a heat gun or hair dryer and melt the ice it the bottom of tray. Clean the water in the tray with some paper towel next get some hot water in a measuring jug and pour into the pan(hot water will help melt ice in tube) repeat this process a couple of times and then get a curtain wire or something flexible to push down the pipe to clean the blockage...you will know when the blockage is clear because the water in the pan will suddenly drain off....put cover back on...make sure to unplug appliance before servicing...hope this helps :)
Jun 22, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
ICE BUILDUP ON BOTTOM OF FREEZER, DRAIN HOLE FROZEN
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
Mar 05, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Jan 01, 2008 | Freezers
GE Freezer &#194; 14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
241 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
