Question about Stanley Bostitch 450S2-1 Wide Crown Lathing Stapler
Stanley Bostitch 450S2 leaks air out exhaust
Stapler just blows air out the exhaust
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
smjdragonfly
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
  • 142 Answers
SOURCE: Describe your Stanley Factory Reconditioned
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Posted on Jul 13, 2009
  • 131 Answers
SOURCE: My Bostitch MIIIFS Floor Stapler wonk work
Sounds like you have a broken driver blade.
Posted on Oct 10, 2009
SOURCE: B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
Posted on Feb 02, 2010
Stapler will not build pressure
did you oil it? It is an oil free, i oiled mine and that happened. i ended up taking it apart and clean out the cylinder , it is easy to do..just use a clean rag no cleaner it might ruin the seals
Jan 16, 2014 | Stanley Bostitch 2 in. Pneumatic Lathing...
How do I put back together Stanley Bostitch 660 Stapler?
HERE IS A GOOD SAMPLE http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
Apr 02, 2012 | Air Tools & Compressors
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
When air is hooked to stapler it leaks from 2-holes by the rubber strike
If the nailer is leaking from the area you discribe, the unit needs to be overhauled as the o-rings are passing air. The kit you need is an ORK-6 O-ring kit. Any Bostitch dearler should have them.
Nov 21, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Sep 27, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
Stanley Bostitch 450S2-1 Wide Crown Lathing Stapler Logo
83 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
