Question about Linksys Computers & Internet
Router will not route to another router of same type
We are running our router from a HN7000s Hughes Net modem, and are trying to route to an other linksys router in seres. The routers are WRT110 Linksys  Routers.
The hughes modem is not a router.
What are you trying to do? Install the Linksys?
Plug the ethernet port on the Hugnes to the "Internet" or "WAN" port of the Linksys.
Then if you go into the config of the Linksys, you can tell if it gets a public IP address.
Posted on May 21, 2009
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
Problems with setting up wireless router wrt310n, wireless printer Dell 968W, Dell XPS laptop and Hughes net
Try reseting the wireless router, theres a reset button hold it down for 30 seconds.
Oct 05, 2008 | Computers & Internet
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Cant hook up
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router
insert satalite into wan port, set up router
run a client wire from the router to a zyxel PL-100
and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
http://www.zyxel.com/upload/images/app_diagram/app_pl100_550x0.gif
Apr 22, 2009 | Computers & Internet
Broadband router
You need to plug your blue cable back into your laptop and the other end needs to go into your hughes modem, or you could leave the end that is plugged into your hughes modem and put the end that is now in the desktop modem into your laptop instead. To have the desktop on the internet you have to remove the end in the laptop and put it into the desktop modem.
The blue cable is spare unless you have any extra sockets that will accommodate it in your hughes modem and have both laptop and desktop connected to it.
Mar 20, 2008 | Computers & Internet
Default IP Adress of the modem Hughes HN7000S
The Hughes addresses are 66.82.4.8 and 66.82.4.12.
Mar 06, 2008 | Computers & Internet
Computers & Internet Logo
198 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
