THE SCREEN GETTING LIGHTER FROM TOP DOWN ON MY PANASONIC VIERA,3/4 OF SCREEN STILL OK
  • Televison & ... Master
  • 9,639 Answers
The screen control circuit board in your tv is failing. Some of the boards are quite reasonable price wise and if you aren't afraid to open the back of your tv , it is an easy job to replace it . The board you're looking for is the one that has one or two wide flat ribbon cables coming out of the bottom of the screen.
Posted on Jan 06, 2014
SOURCE: panasonic viera 37"
... the problem was presenting when switching on the tv... the temporary solution was to press the a/v button, hope this can help
Posted on Oct 03, 2007
  • 458 Answers
SOURCE: 2 yr old Panasonic Viera 37 in - has very narrow
This is a fault developing within the screen, the only remedy is to have the screen replaced, there is no exact answer to why this has happened, it is just the nature of a plasma screens make-up that sometimes a fault can develop like this within the characteristics the display
Posted on Nov 16, 2009
Testimonial: "Thanks. Might have to live with it as it sounds expensive to replace!"
  • 65 Answers
SOURCE: panasonic viera with vertical lines down the screen
Either the buffer board is bad or the plasma panel,sometimes it coult be bad connections on the interconnect ribbon cables from the plasma panel to the buffer boards.
Posted on Mar 19, 2010
agibbsholden
  • 30 Answers
SOURCE: I have a panasonic viera
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Posted on Oct 30, 2010
  • 3 Answers
SOURCE: Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Posted on Dec 04, 2011
Hello, I have a 2 years old Panasonic Viera plasma TV and there are many horizontal lines going from the top of the screen to the bottom... No matter which input is used...
You're discussing about the 'supply HUM' I assumes. Check all the external connection to TV inputs for firmness first. If all are found OK, check by replacing all the filter capacitors at its main power supply regulator board. In fact, replace the power supply board as card basis will be the best. For more information go to http://electronicshelponline.blogspot.com/
Dec 05, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera black line split screen horizontal 3/4 left 1/4 right
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Aug 08, 2012 | Televison & Video
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
How do you remove the self check on a panasonic viera 37 in lcd tv?
Hello:
This procedure will bring up the self test screen and reset the unit to factory settings for you.
First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Oct 10, 2011 | Panasonic Viera TC-37LZ85 LCD TV
I cannot turn off closed caption on screen. Panasonic Viera Plasma TH 42PV60A
hi,
To exit closed caption do the following.
1. Press the menu button and select CC and press OK button.
2. In CC menu select MODE and using right arrow or left arrow button select it OFF
3. Press OK button
4. Press menu button to exit menu option.
ok
Mar 10, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Top half of picture is black
How to access the self-check screen to reset the unit.
Select a television channel, and while pressing the [VOLUME ( - )] button on the main unit, press the [OK] button on the remote control for more than 3 seconds.
How to Exit the self-check screen
Press and hold the Power button on the TV for 5 seconds or disconnect the AC cord from the wall outlet
Jan 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Shop mode keeps appearing on the screen
call panasonic they can walk you through the steps to get it off or look in your user manual.
Jan 11, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I have a panasonic viera plasma and suddenly have a 1' black line going down my screen
Sep 15, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Hi, the lower half of our Viera screen is unviewab...
Yes the problem is the following.
Either the ysus board is defective or the y buffers are faulty.
more likely the ysus board.
May 20, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera not fitting screen - 32"
The problem was with the cable/sky decoder. I changed the aspect ratio on the decoder not the tv.
The TV was not the problem.
The problem is that the decoder is sending a 4:3
picture to the tv this needs to be changed to 16:9 in the set up menu on
the decoder.
Sep 26, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
