Question about Sony Ericsson S312 Mobile Phone - Silver
Data connections - Sony Ericsson S312 Mobile Phone - Silver
How can i switch off data on my HTC phone ?
  • On most Android phones (ICS, JB, KK): go to Settings -> Data Usage -> Data Connection -> Slide the switch on off
  • On some HTC phone: use the Data Connection widget
  • On some Android phones (1.5 - 2.3): go to Settings -> Mobile Networks -> uncheck Data Connection
Other ways:
How to Turn Off and Disable Mobile Data Connection 2G GPRS Edge 3G on...
How to Disable Mobile Data Usage Beginners Guide
Enable or Disable Mobile Data Android 4
How to disable the internet connection on your smartphone turn off your...
Aug 25, 2014 | HTC Magic Cell Phone
How i connected zte skate to data service
Please check the data services with your service provider because if you do not activate the internet data package on your phone then you'll not be able to get connected to internet....
Jan 18, 2013 | ZTE Skate
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
How to transfer data from computer to mobile through usb
first connect your mobile through data cable.when connecting your mobile will ask the type of connection.choose data transfer or data storage.then new drive will be formed in your computer.just copy and paste your data to your phone.
Dec 28, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to gprs nokia
Follow these steps :
1.
Select "Menu," then "Settings."
2.
Select "Connectivity," then select "Packet data."
3.
Select "Packet data connection."
4.
Choose between the two options to enable GPRS. Select "When needed" to enable data connection only when it is needed by an application. The connection will only open when applications are running. Select "Always online" to set the device to always connect to the packet data network automatically when the device is turned on.
Oct 30, 2010 | Facebook Computers & Internet
Iam not able to install bsnl3gmobiletv on my samsungGT-S5603.I live in barmer(rajasthan).Thereis 3g service avaliable here
You musy define three access points.
1. bsnlnet : a) Connection name - bsnlnet b) data bearer - packet data c) APN - bsnlnet d) Authentication - Normal e) Home page - www.bsnl.co.in
2. Bsnl Live - a) Connection name - Bsnllive b) data bearer - packet data c) APN - bsnllive d) Authentication - Normal e) Home Page - www.bsnllive.com
3. Bsnlstream - a) Connection name - Bsnlstream b) data bearer - packet data c) APN - bsnlstream d) Authentication - Normal e) Home page - www.bsnl.co.in
One more to be defined is Packet data Connection - When needed Access Point - bsnlnet
Mar 15, 2010 | Cell Phones
How can i connect to packet data. im using nokia 6111
check ur settings and restart the phone after sometime if problem continues ask ur service provider
Aug 05, 2009 | Nokia 2600
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Sony Ericsson S312 Mobile Phone - Silver Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
