Question about Breville RC2 10-Cup Rice Cooker
Instruction manual I need a new power cord for this unit - 10A 250V. Can I buy as a replacement in a DIY Electrical store?.
How do I buy a new power cord for my TV set?
These Mains cables are standard & you should be able to buy one from any electrical store.
Dec 26, 2012 | LG 47LG50 47LG50 47-inch 1080p LCD HDTV...
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Tv wont switch on by manual on/off button, button wont stay in
The switch is damaged internally, will need replacing with a new one so some soldering is required, they are normally 250V between 2 -10A Rating.
Nov 05, 2009 | Goodmans W280NS Television
Where can i buy a new power cord
HI,
YOU CAN BUY A POWER CORD IN ANY ELECTONIC SHOP OR IN COMPUTER SHOP,
BUT REMEMBER TO TAKE GOOD VOLTAGE CORD IE,15A 110V/250V 3 PIN OR 2 PIN IN 5 AMPS.COST WILL BE AROUND $ 3 TO 4.
TNKS
RABBANEES
Nov 04, 2009 | Lexmark P315 InkJet Photo Printer
Power cable replacement
you can buy a power cord in any electronics parts store...cut the cord to have a sample...you can connect the new one by splicing it.and twisting it and you should put an electrical tape to it..to make it insulated..
Sep 10, 2008 | RCA 32V550T 32" TV
Continuing questions from Tony Fidaleo
I've sent you an email to request the copy of your PDF file to see what part in the circuit is making the fuse blow.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Breville RC2 10-Cup Rice Cooker Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
