Question about Acer Aspire 5004WLMi Notebook
Cd drive is there a trick to pulling the cd drive out on a aspire 5004wlmi
Yes, I have done this.
Step 1: With the laptop closed, unplug the power cord. Remove the battery by pushing open the 2 little locks on the bottom of the unit.
Step 2: Unscrew the three screws in a single row across the back of the unit. They are on the same plain as the serial port connector. These are the screws that hold down the on/off switch plate. Save the 3 screws in a container.
Step 3: Now, with the laptop (upright and opened) on a table slowly and carefully lift off the switch plate, located between the keyboard and the screen. Be very careful because it has tabs on it that can be broken. Slowly and carefully work the plate loose and remove it.
Step 4: Remove the two screws that hold down the keyboard and carefully, slowly lift the keyboard. Save the screws in a seperate container. There is a ribbon connector under the keyboard connecting it to the motherboard. Don't stretch it tight and don't disconnect it. Loosen and remove the screw in the middle of the keyboard recess under the keyboard.
Step 5: With that screw removed you will be able to slide out the cd drive. If it hangs up part way out, jiggle the battery lock next to it and gently pull it the rest of the way out.
Posted on Jan 23, 2008
I would like to reboot my acer laptop 5004. It will not read the disc.
there is something wrong with your can change a cd-rom or you can look aion kinah and cheap aion gold
Feb 03, 2010 | Acer Aspire 5004WLMi Notebook
Zapped the monitor backlight on my acer aspire 5004WLMi
check the ebay listings, you should be able to find the parts you need.
Jan 10, 2009 | Acer Aspire 5004WLMi Notebook
Acer Aspire 5004 keyboard
You need those tabs. The reason those tabs are there is to hold the keyboard in place. Replacements are recommended ONLY if you take it to an authorized service center.
Feb 29, 2008 | Acer Aspire 5004WLMi Notebook
Acer laptop keyboard
Your only solution is to contact acer and purchase a new keyboard or look for one on ebay. Sorry
Acer Aspire 5004 laptop
yes hard drive may be malfunctioning or it may be a virus
you can try using a diagnostics tool to be sure
if its faulty or not
here try this
after downloading file you will need to write iso to cd using a program like imgburn
you will then need to boot from the cd
you can change the boot order so that it boots the cd first on your laptop's bios
Feb 23, 2008 | Acer Aspire 5004WLMi Notebook
Pls help me. unable to burn cds in my laptop
Make sure Standard CD/DVD burning is active if its not active check the option and apply as indicated below
If issue persist please post for alternate steps.
Good Luck
Feb 06, 2008 | Acer Aspire 5004WLMi Notebook
More info on the problem.
do fomatt 1st do u have orginal xp cd del partions then make new ones then formatt them quick install xp ok
Jan 23, 2008 | Acer Aspire 5004WLMi Notebook
My Acer Aspire 5004WLMi Crashed and will not boot with Acer recovery disks
turn on your computer when it stars to boot up simultaniously press F8 button run for safe mode then try to launch system restore.
Jan 21, 2008 | Acer Aspire 5004WLMi Notebook
Acer Aspire 5004WLMi Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
