Question about Maytag Atlantis MAV8551 Top Load Washer
When the washer goes to the rinse cycle it does not fill it just keeps running water in the tube.............Maytage Atlantis
  • 4 more comments
  • sgwinn May 21, 2009
    It goes through the wash cycle and when it gets to the rinse cycle the water just keeps running and running and running it tube never fills up.
    It runs in the tube but drains as fast as it runs in. I woke up last night after starting a load at 9 and it was running at 11.
  • sgwinn May 22, 2009
    It only happens sometimes. After the wash cycle is over and the water starts running in to rinse it does not fill the tube but keeps running and draining the water. Never fills up to do the rinse just keeps running water that drains out.
  • Mike Inman May 11, 2010
    need more info
  • Michael Masters
    Michael Masters May 11, 2010
    where dose the water go if it doesn't run into the tube and, is the flow slow or fast?
  • Michael Masters
    I'm confused, you said it dose not fill but then you say it just keeps running water in the tube????
    Help me understand your issue please...
  • 32 Answers
Check washer drain hose if it is all the way in your drain line take out put it back only 6 to 8 inch in your drain line. i think i will solve your problem.
Posted on May 24, 2009
    Champion:
  • 219 Answers
Is your drain hose laying down on the ground or down real low because that would be the only thing i could figure
Posted on May 26, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Our well pump went out and was replaced, there has been some silt from the well and we have cleaned the water filters in the lines. when the washer goes into the rinse cycle, the water goes down to a...
Sometime there are water screens in both the hoses and the water vavle. Given you mentioned that in the rinse cycle the problem most often occurs it seems you still have cold water clogged screen issues. Turn off your water hoses and remove them at both the water valve and the hose bibb faucetts. Remove and Re-clean the screens under running water with an old tooth brush. It is not uncommon for a water system that has had silt intorduced into it to cause water fill flow problems for quite some time. That silt has settled in your pressure tank and your hot water heater. I would recommend that you attempt to drain and re-fill them both to at least minimize further silt introduction. In the mean time clean your inlet screens in the water lvale and hoses as often as necessary until the problem goes away.
Jan 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer machine is overflowing at fill up and rinse cycles.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear
Dec 22, 2009 | Maytag Washing Machines
Rinse cycle wont fill
check your drain hose. needs to be at hieght of tub before entering the drain....should only be 3-4 inches in the drain and secured with a ziptie.
Jun 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Cold water will not run into washer, but drips when washer is off
Take the hose off the back of the washer and remove the screen and you will find it to full of sediment. Clean it out and try again.
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
221 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
