Question about Konica Minolta Office Equipment & Supplies
Trouble code C-D252
Unable to clear by switching off and restart, call engineer
  • Konica Minolta Master
  • 1,294 Answers
The CD codes refer to imaging process abnormality.Try to reset by :
Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Keep pressed the Utility key when on the screen appeir Trouble reset.Touch the message and turn OFF the copier.Wait 1 minute and turn ON.
Posted on Jan 02, 2014
2002 hd 1400 has a #2 code showing up will not clear
If you've got that Engine light coming On for 4 seconds, Off 4 seconds then On 8 seconds then out, its historic. (there WAS a problem that has now cleared)
If its On 4, Off 4 then remains On its a 'current' code.
I never heard of a #2 code.....they are read as a two digit code.
Here's one method some use to clear all codes:
Disarm alarm if so equipped.
Run/Off switch to OFF
Ignition Key: ON,OFF,ON,OFF,ON (and leave ON)
Press LEFT turn signal switch TWICE. Wait for 1 or 2 flashes..
Press RIGHT turn signal switch ONCE => turn signal will flash 1 time
Press RIGHT turn signal switch ONCE => turn signal flashes 2 times
Press RIGHT turn Signal switch ONCE => turn signals flash 3 times
Press LEFT turn signal switch ONCE. TROUBLE CODES WILL NOW BE DISPLAYED
TO CLEAR ANY CODES,,,=> PRESS & HOLD LEFT signal switch for 5 seconds. => turn
signal will now flash twice to confirm memory is clear.
Turn ignition OFF.
Sep 28, 2014 | Harley Davidson FLHX Street Glide...
After HEET in full Tank car ran with message "Reduced Engine Performance"
If you have that message, you've got trouble codes stored. Get the trouble codes read. That's ALWAYs the starting point.
Oct 19, 2017 | 2009 Volvo C30 T5
Clearing trouble code C-D252 on Bizhub 253c
missing the a circuit board for you print controller
Jan 02, 2014 | Konica Minolta Office Equipment & Supplies
Trouble code p1491, rad fan relay.
Did you clear or erase the codes after you replaced these parts?
Dec 05, 2013 | 2000 Dodge Dakota Quad Cab
What is the code for Comcast universal remote to control an apex d252 digital converter box
What is the brand name of your device? Try this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there.
May 18, 2013 | Televison & Video
Cranks strong, wont start
could possibly be a crank sensor, not sending a signal to allow any power to the ignition
Feb 05, 2012 | Cars & Trucks
ABS light comes on... but no noticble degradation in operation etc.
Most likely a wheel speed sensor, hopefully... The only thing that will change when the ABS light is on is that the ABS will not function as long as the indicator is on. I hope this info helps.
When the airbag system is in functioning condition, the airbag warning light will remain on for about 7 seconds and go out when the ignition switch is set to ON .
If there is any malfunction, the airbag warning light will either stay on or off continuously. In such cases, perform on-board diagnostic in accordance with the specified procedure to determine trouble codes.
  1. Turn ignition switch ON (with engine OFF ).
85091723
  1. Connect DIAG. terminal to No.2 terminal of diagnosis connector located inside lower cover.
  2. Check in accordance with the trouble code indicated by the AIRBAG warning light, and record the trouble codes.
  3. Turn the ignition switch "OFF " and remove the DIAG. terminal from No.2 terminal of diagnosis connector.
85091724
HOW TO READ TROUBLE CODES
The ABS lamp flashes a code corresponding to the faulty parts.
The long segment (1.2 secs on) indicates a "ten", and the short segment (0.3 secs on) indicates a "one".
NOTE: This is the only information provided by the manufacturer for clearing diagnostic trouble codes.
97511505
CLEAR MEMORY
After eliminating problem as per trouble code, clear memory as follows:
Make sure ignition switch is ON (and engine off). Connect one DIAG. terminal (1) on diagnosis connector (2) terminal No.1.
where warning light is flashing, connect the other DIAG. terminal (3) on terminal No. 2 for at least three seconds . After memory is cleared, normal warning light flashing rate resumes. (Warning light flashes every 0.6 seconds (ON-OFF operation.) Memory cannot be cleared if any problem exists.
After clear memory and then DIAG. terminals (1) and (3), extract from diagnosis connector (2)
Jul 27, 2011 | 1999 Subaru Legacy
I keep hearing that I need to find and pull fuse 14 on my 96 subaru legacy 2.2L to try and reset the AT Oil Temp light that is flashing at start-up. The lid is missing, so I have no idea where this fuse...
Yes that is right:
Current trouble codes shown on the display are cleared by turning the ignition switch OFF after conducting self-diagnosis operation. Previous trouble codes, however, cannot be cleared since they are stored in the ECU memory which is operating on the back-up power supply. These trouble codes can be cleared by removing fuse 14 (located under the right lower portion of the instrument panel).
  • The No. 14 fuse is located in the line to the memory back-up power supply of the TCU and ECU (MPFI). Removal of this fuse clears the previous trouble codes stored in the TCU and ECU (MPFI) memory.
  • Be sure to remove the No. 14 fuse for at least the specified length of time. Otherwise, trouble codes may not be cleared.
When the Engine Control Module (ECM) , battery terminals, etc. are disconnected after memory is cleared, idling speed may increase. This is not considered a problem because the ISC Valve duty controlled learning value has been cleared. To return the engine to idling speed, idle for approximately 2 minutes with air conditioner "OFF".
Here is fuse #14 loc in panel Now its hard to see, but they go from the top left from 1 - 7 then it repeats for the next row 8 - 14. SO 14 is 2nd row from the top last one on right side.
118890618 118890619
Mar 09, 2011 | Subaru Legacy Cars & Trucks
Reduced engine power silverado 2006.Engine light came on.Stopped vehicule shut off engine and restarted.engine light stayed on and had lots of power.
You need to have the computer scanned for trouble codes. Whatever happened stopped after you restarted the engine, but the engine light wont go off until the ignition cycles many times without any problems. Any parts store will scan your truck for free. Have them scan it and clear the codes, and come back here and let us know what code/s you get.
May 16, 2010 | 2006 Chevrolet Silverado
296 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
