Question about Miele Coffee System
Saeco reset coffee counter - Miele Coffee System
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
Saeco royal professional machine started giving half cup less coffee then normall
Do you know how to reset the amount of the cup amount. I have a different saeco model but this mite help. Press the button for a coffee and keep it pressed in this is how you reset the level on mine when you release the button it resets the level.
Nov 09, 2013 | Saeco Coffee Makers & Espresso Machines
My Saeco Primea Touch Plus every time I turn it on says to add detergent at the milk conteiner. After I give the comand it tryes to wash the milk conteiner and when this is finished says to turn of the...
From what the User Manual indicates, the prompt to clean the milk circuit is based on the number of days since the last time this was done. The counter which keeps track of this is probably only reset at the completion of the wash cycle. You might be missing a step.
The User Manual is available here, see page 28. There are 16 steps plus the "perform another rinse cycle" (page 27):
https://www.seattlecoffeegear.com/assets/user-manuals/saeco/saeco-primea-touch-plus-user-manual.pdf
Jan 14, 2018 | Saeco Primea Cappuccino Touch Plus Coffee...
After making coffe red ligth is on, coffe is just fine?
Which red light is on? It may be that youa re emptying the dreg drawer with the power off. When you do this it doesn't reset the counter that tunrs that light on
Feb 14, 2011 | Saeco Vienna De Luxe Espresso Machine
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Saeco Vienna Digital
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Miele Coffee System Logo
21 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
