Question about Vacuums
My wertheim 5035 won't shut properly when trying to put a bag in? Does anyone know how to fix this problem?
  • Anonymous Mar 31, 2014
    Lost Manuel
    Need a Manuel for a wertheim 5035!
  • 55 Answers
Sounds like something is not propertly aligned. Try repositioning -- do not force it!
Posted on Jan 02, 2014
2 Suggested Answers
SmartAlec
  • 171 Answers
SOURCE: How do you open a wertheim 2000P vacuum cleaner?
SmartAlec from NelsonVacuums.com.au here. The ET2000 has a latch that is located at the very end of the machine lid (about 6 cm in front of where hose clips in. If you sit the machine up on its back end you should see the black lever that needs to be pushed in. Now I will also say that it is possible that you have actually been pushing this but the lid still wont open, this is because every now and again the whole latch moves itself out of alignment by about a milimetre. The easy fix for this is a gentle screw drive to assist the relesing of the catch, this needs to be gently pushed in at the same time as squeezing the latch (hand at top of latch screwdriver at base kind of toward the middle of machine). You should be able to get it open like this with only light pressure. Now of course if you need bags or filters please visit us at NelsonVacuums.com.au.
Kind regards Alec
Posted on Aug 02, 2010
Wertheim 5035
Check the dust bag. If it's full or the hose is clogged the motor will overheat and a safety device will shut the motor off until it cools down.
Apr 07, 2014 | Vacuums
Kind regards Alec
Aug 02, 2010 | Vacuums
My wertheim 6030 is overheating I have changed the bag and filter even though there was no indication this was needed now it wont turn back on
Have you removed the bottom of the vac to be sure there is no obstructions? Check the intake area for an obstruction. Also look around the motor for vents. Are they clear? Most new vacs have a reset button. This will typically reset the motor. If none of this helps try reinstalling the filter and bag. I am not familiar with this model but most of this should apply.
Dec 03, 2009 | Vacuums
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
