Question about Curt 1998 Chevrolet C/K 3500 Crew Cab Trailer Hitch - OEM style
98 Chevy crew cab diesel, need to tap box near key ignition to start, is there a sensor in steering colummmn
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 331 Answers
GM uses an on-board anti-theft system. It is located inside the steering column. It is tamper proof. If a thief shocks the ignition key cylinder then it will enable the the " No Start" program. Also if the ignition key cylinder assembly get loose and worn. The Security system will start to malfunction. Call your local GM/Chevy Dealer for price and availability for a new unit or let them fix it. Let me know if that helps, good luck.
Posted on Mar 03, 2014
My chevy C3500 4x2 diesel crew cab is turning over but wont start i checked all the fuses do u think it may be at fuel pump r a line stopped up or a senser
You need air, fuel, and spark to start your vehicle. It may be the fuel pump, filter, fuel pump fuse/relay. You should be able to hear the fuel pump kick on when you first turn your key. Fuel goes to the pump, filter, lines, and engine. If it is getting gas, you need to check for spark. Spark plugs/coil wires, distributor, dist.cap, cam sensor, ect. It can be anyone of them. Check for gas and spark.
Mar 06, 2011 | Chevrolet C3500 Cars & Trucks
Where is the turn signal\hazard flasher located?
it's in the auxiliary relay box behind the glove box.
13350 is base part number on flasher
Feb 03, 2010 | 2003 Ford F250 Super Duty Crew Cab
1999 chevy express. intermittent the antilock light comes on, fans shut off and cruise control shuts off. when it comes back on the brake light turns on and front and rear fans restart
I have the same problem on my 2000 chevy crew cab dually keep searching and searching the internet but no one has a cure for this problem. I found it !!!! It is the stupid little black box under the ignition where you put the key in. I tapped it with the screwdriver and the effects kept reversing......light and fan off, then on.....each time I hit it. At least I found the problem area !!!! If you have any questions feel free to email me. chevy720@msn.com
good luck !
Oct 31, 2009 | 1999 Chevrolet Express
Tapping noise near computer 1994 Chevy 1500 Silverado
air recir actuator motor shorted you can reach between blower motor and heater case and unplug a pain to replace
Oct 29, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Need to replace 1997 e350 ford Ignition ,how can i
you dont have to remove the steering wheel on a most Ford car and trucks you insert the key turn to the on position and there is a small pin under the ignition switch that you push and it comes right out.you have to remove the steering wheel cover above and below the ignition switch.
Oct 04, 2009 | 1997 Ford F350 Crew Cab
98 chevy s-10 codes p0131, p0171, and p1133
Your O2 sensor is starting to go bad .recomend replacement before it gets worse
Sep 24, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
How do i remove the ignition swicth from a 2004 chevy siverado 1500
The procedure to remove the ignition switch is
  1. Start by disconnecting you negative battery cable.
  2. Wait at least 1 minute to disable your airbag system.
  3. Remove the airbag from the steering wheel, it's retained by a couple bolts on the back of the steering wheel.
  4. Disconnect the wires to it, and set it aside.
  5. Remove the clip that is above the lock nut for the steering wheel, then remove the lock nut.
  6. You need a steering wheel puller to pull the steering wheel off. After you remove the steering wheel, you should have access to the turn signal switch.
Sep 18, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
I need to replace My steering Column and I dont know If I can interchange it with any years common to the 1990 Chevy Chyenne Pickup truck With a manul transmission
yes you can as long as it is 88-98 years the main electical plug may be diferent just cut and splice the wires together blue to blue red to red so on if thare is two of one coler twist them together it will work fine.
Mar 11, 2009 | 1990 Chevrolet Crew Cab
Steering pulls to the right
No adjustment, sound like gearbox has failed, be sure to flush power steering system before installing new gearbox.
Jan 18, 2009 | 1996 Ford F250 Crew Cab
Still has power to interior
Sounds like a bad ignition switch, usually in the steering column under the plastic, it should be only around $40. try AutoZone if it doesn't hellp they're good about returns
Dec 26, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Curt 1998 Chevrolet C/K 3500 Crew Cab Trailer Hitch - OEM style Logo
539 people viewed this question
Top Curt Sport & Outdoor - Others Experts
Are you a Curt Sport and Outdoor - Other Expert? Answer questions, earn points and help others
