Polaroid 40" P40Led13 tv my plug in Toshiba dvd problem
Polaroid 40" P40Led13 tv my plug in Toshiba dvd keeps changing back to the tv channel again.
  • Margaret
    Margaret Jan 04, 2014
    When watching a dvd it suddenly switches back to the tv channels on cable and I have to change it back with the tv control source button to the dvd again
4 Suggested Answers
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
  • 148 Answers
SOURCE: When I turn on the tv the word Polaroid appears
Hi there, I don't completely agree with the previous opinion. The problem lies not in the lightst....he caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped(or not) please rate, thank you!ecd8d91.jpg
Posted on Feb 05, 2010
Testimonial: "Awesome, thanks alot."
rylee_smith
  • 8619 Answers
SOURCE: My 40 inch Polaroid LCD tv screen won't come on
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight and/or an inverter board issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire inverter board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. The cost to change the inverter board including labor would be around $250, if you get this done by a professional. Please revert back for more help.
Rylee
Posted on Dec 23, 2011
Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Jan 11, 2014 | Televison & Video
Toshiba TV/DVD Combo Model MD14H63
I have the same problem with this model as Guest, who posted on 01/03/2008: power on, red light, immediate shut-off. The sticker on the television says it was manufactured in April 2007. I think there should be a warranty on it; I suppose I'll be calling Toshiba soon if it doesn't start working. Maybe important to note for any potential buyers, as well.
Dec 25, 2007 | Toshiba MD14H63 14" TV/DVD Combo
Can't program the channels
Here is where I found the remote code (1256) for the TBX-2000AF and it has many more codes for Polaroid models. Good luck (copy and paste this link) http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/popup_adp.php?p_sid=fPLB5Gzi&p_lva=&p_li=&p_faqid=2854&p_created=1116267791&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD0xOTk0JnBfcHJvZHM9JnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MQ**
Apr 15, 2007 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
