Sharp washing machine
I have a digital sharp washing machine the problem is that, when i set it to the spin mode it appears error and it wont spin
    New Friend:
I have washing machin fully atomatic pcb bord folt.pleZz help me
Posted on Apr 30, 2017
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
You need to check the motor brushes
Posted on Jan 02, 2014
SOURCE: my washing machine wont spin
How do you open the top to replace the lid switch?
Posted on Nov 06, 2008
SOURCE: sharp washing-machine
check the machine's solenoid, most probably that is the problem
Posted on May 02, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Washer won't finish spin No error codes
check the pressure is not sticking in the high position if the pressure system is blocked the air might be slow getting out stopping the pressure switch from dropping to low level by the time you get to the machine it has had time to drop to low and will allow the machine to spin
Mar 11, 2014 | Indesit Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
The digital readout is showing f 11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08.
Thank you !!
Jul 30, 2010 | Kenmore Elite 45986 Front Load Washer
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Frigidaire front load washing machine gtlf490e
just change the door switch been there done that have the t shirt
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Motor will not start in slow agitate
I rewound electric motors in the past, in your case i don't know if its a armature motor it would have brushs. if it was if its without brushs, it would have two septrate windings one for spin, one for wash. the wash windings could be 'faulty',answer! try other motor! if you get one. let me know which motor it is Ire,Close. bye for now
Dec 02, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
