Question about Samsung UA40C5000 40 LED TV
Can't be turned on. Last used a week ago, now no red light at all when power is supplied.
Last used the TV one week ago, took out the plug after using. Now, I plugged back in and there is no power at all, no red light, as if there is no power. Is there anything I can do about this?
  • Samsung Master
  • 9,633 Answers
Make sure the cord is pushed in all the way on the back of the tv. If it is then check for fuses on the power supply board inside the tv
Posted on Jan 06, 2014
  • 210 Answers
SOURCE: samsung flatscreen wont turn on but red light is
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Posted on Dec 19, 2009
  • 4 Answers
SOURCE: samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Posted on Jan 19, 2010
milkburp
  • 416 Answers
SOURCE: power wont turn on the red light in front of tv is blinking
You need some capacitors changed on your power supply. Easy job if you can use a soldering iron. I have a tutorial in my Tips & tricks. Remove the rear cover and locate the bad capacitors (little plastic wrapped canisters with swollen tops) near the top right of the tan PCB board on the left-mid side of the TV. Note the values written on then (1000uf or 2200uf) then head to radio shack and purchase the replacement parts. Ask for 16v or 25v parts (16v fit better). Replace the parts, put the rear cover back on and you are all set. I hope this was helpful.
Posted on Mar 21, 2010
SOURCE: Samsung Series L3 360 TV
how to use pen drive in it
Posted on Jun 30, 2010
Slinteriors
  • 8617 Answers
SOURCE: Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Posted on Mar 02, 2013
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
My audiovox 32" 3205 died a few weeks ago and took
Not a projection set if 32 inch---If looks like blotches try turning set with it on to see if they change--if so you may have not plugged the degaussing coil (usually a two pin plug) back in when you did the repair--it goes on the power board.
Jun 16, 2012 | Televison & Video
Hl-s4266w Powers on for about 15 seconds then turns off. Was told it is a timer that needs to be turned off by using factory remote - I have lost the remote! now what?
Not sure about the timer. Our 55" samsung broke last week and it was shutting on/off no picture just turn on music recycling off/on. The blue light was lite on TV and red light to the right was blinking. The TV repair guy replace the Power Supply board b/c of swollen capacitors, was under warranty. The board runs about 70 bucks though. Took him all of 5 mins after unscrewing the back cover of TV. The board is at the bottom center after cover is removed. Hope this helps
Mar 18, 2010 | Samsung HL-S4266W 42" HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
Akai Model LCT3701AD: bought two years ago from Sam's Club at discounted price with no remote control and no service manual. I tried to find a universal remote but couldn't find one that will work on this...
If the TV fails to power ON, in about 90% of the time is due to a defective power supply.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Jun 30, 2009 | Televison & Video
My Voyager won't charge. I plug it in, and it doesnt even say anything. I have tried different chargers too.
This happened to me last week. The pins inside your charger port must have been shifted (pushed up or down). The plug, once inserted does not go all the way through or is not fully inserted within the port. To fix this, get a butter knife (this is what I used) or something flat and skinny that would fit into the port. Then, push it down or up to the middle. Try connecting the plug and check if it's now charging. I hope this works and helps you.
Jun 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
May 30, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung UA40C5000 40 LED TV Logo
90 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
