Question about DeLonghi Coffee Makers & Espresso Machines
DeLonghi is stuck on initial heating up cycle
My DeLonghi ESAM540 is stuck on the heating up cycle that follows the initial start up 'self check' process and never makes it to the rinse cycle - so no functionality comes on & thus no coffee. Has anyone had a similar problem and/or a possible solution or even know the magic combination of buttons to press on 'turn on' to activate the program mode immediately?
3 Suggested Answers
  • 3 Answers
SOURCE: Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Posted on Feb 19, 2009
  • 109 Answers
SOURCE: Gaggia Titanium stuck on RINSING CYCLE
Let it rinse it may run for some time.
you will not be able to remove the brew unit as it is engaged to be rinsed.
Posted on Feb 22, 2010
Stuck in rinse cycle when the unit is powered up
Try reset try going into menu try and follow the rest of program
South system can concludes
Apr 27, 2015 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Self Test not started for DeLonghi EC850
I think it's to late but for others how meet the same problemFirst use must begin a self clean using the tape for hot water and press the blinking water drops button
Dec 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Where is the electronicnautomatic temperature control module located on a 05 ford 150
I assume you have checked all fuses. It could be the heater control switch , the blower motor resister , I would start testing if power is getting pass the switch to the blower motor.
Nov 28, 2009 | 2005 Ford F-150
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
It starts then stops. never completes the cycle. it shuts down. it will drain thats it.
If the cycle didnt complete check the following:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place doing one function continuously the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Sep 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Oven wont heat
That depends if the oven is electric or gas.
If it is electric, it can be heating element, temp probe, or control knob/buttons, board and wiring.
If it is gas it can be the igniter (check spark) , the thermostat, the safety valve that prevents accidental gas flow, or the control.
If the oven has self cleaning cycle, check that it is not stuck on self cleaning, try unplugging for a while and restarting self cleaning cycle in that case.
Check also What is wrong with your Range/Stove/Oven?
Mar 29, 2009 | Ovens
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Need to initiate cleaning cycle
to enter the cleaning cycle:
Select the RINSE & SPIN button.
Select Low SPIN SPEED'
Select Warm/Cold WATER TEMPERATURE.
Select the 2ND RINSE Option.
Push the END of CYCLE SIGNAL button 4 times within 5 seconds to start cycle
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
Stopped brewing
Tim, I do not have any pics of the fuse. If you follow the 2 wires that connect to the element upwards you will find it. It is covered with a heat resistant sheath.It is right next to the heating element. The fuse is maybe a half inch long with wires on each end. I believe mine was silver. Good luck, I hope this helps you. Mark.
Jun 10, 2008 | DeLonghi DCM485 Coffee Maker
Coffee Makers & Espresso Machines Logo
172 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
