Question about Acer Aspire Computers & Internet
MEDIA TEST FAILED CHECK CABLES INSERT DISK AND PUSH ANY KEY DONT HAVE DISK
    Top Expert:
  • Acer Master
  • 26,659 Answers
If you press F8 just before it boots, select repair. If the system is working you should get the option to repair the OS.
Posted on Jan 02, 2014
zabolyx
  • 38 Answers
SOURCE: comp won't boot
This could also happen if the hard drive is dead and trying to boot the next item or the BIOS has the Netboot option set as the first boot device.
Jump into your BIOS and make sure that the boot order is CDROM then USB then HDD. Then try again. Let us know what happens.
Posted on Apr 02, 2009
leecom72
  • 4806 Answers
SOURCE: realtek media test failed check cable pxe exiting flashing
As the computer starts hit F2 to get you into the bios, look for boot options and set the HDD (hard disk drive) to the first boot device, hit F10, save the changes and exit the bios. The computer will restart and should boot from the hard drive. If it doesn't go back into the bios and look to see if the drive is recognized in the main page of the bios.
If the hard drive is not there then there could be a chance that the hard drive has failed.
Please let me know how you get on and if you need any further assistance.
Good luck.
Posted on Aug 26, 2009
benwabnick
  • 2404 Answers
SOURCE: media test failed, check cables
Sounds to me like there is bad sectors on the hard drive. Replace the hard drive with a known working one. If you still get that error message then at that point try different memory in the laptop.
If it still doesn't go away then its a motherboard issue at that point.
Posted on Nov 30, 2009
SOURCE: PXE E61: media test failure, check cable PXE-MOF:
try to check if your hardisk is plugged properly, i had encountered it before. same response i got from the computer. "insert boot disk and press any key"
Posted on May 03, 2010
Keynan
  • 977 Answers
SOURCE: PXE-E61 : Media test failure
It sounds like your hard disk has gone, or not being recognized by the computer... Check if it seats well in it's place.
Unfortunately, laptop HDDs don't last long these days.
Posted on Oct 18, 2010
Gateway nv7915u error message i'm getting is pxe-e61 media test failure check cable pxe-m0f exiting broadcom pxe rom no bootable device--insert boot disk and press any key but when i do that nothing...
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Nov 04, 2011 | Gateway NV7915u Notebook
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.07 (080320) PXE-E61: Media test failure, check cable. PXE-M0F: Exiting PXE ROM. No bootable device -- insert boot disk and press any key thanks
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 26, 2011 | Toshiba Satellite Laptop
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Media test failed, check cables
Nov 30, 2009 | Acer Aspire 5100-5022 Notebook
Media test failure, No bootable device, insert boot disk.
Media test failure, no bootable device error message means the hard disk has failed, therefore cannot boot up.
If reseating the hard drive doesn't fix your problem then replace the faulty drive and install Windows on the new drive to get the computer operational again.
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Thinkpad x60 reboot fails. Error message: Media test failure
plz check the hard disk data cable(cable which is connected to motherboard), if changing the cable do not solve the problem your hard disk may be corrupt
Mar 01, 2009 | IBM ThinkPad X60 Tablet PC
Will not boot up ( acer aspire with vista basic)
0xa 0000000 is a hard drive error .. either your controller or your hard drive has failed ..
Dec 28, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
