Question about Cell Phones
Light not turn off
THE WHITE LIGHT ON MY NETGEAR NTV300 WOULD NOT GO OFF
Wireless internet connection trouble
Your question is vague ? What trouble are you having ?
Are you using WPS (like auto setup Wi FI from Router) or manually where you look for the wi fi name (ssid) and select it and then you pick the encryption WEP or WPA and put in the encyption key . Which may be on the case of the router or you can log into the wi fi router and find out what encryption is being used and what the key is. Have you read the manual page 25 ?
https://www.manualslib.com/manual/669193/Netgear-Ntv300.html?page=25#manual
Feb 13, 2015 | NetGear NeoTV NTV300
How do I get neo tv to work again , bottom of screen says fatal: internal storage failure
Sounds like the internal hard drive has failed. Most places that know how to fix computers should be able to help. I don't know how much your neo is worth, but a new hard drive could cost anywhere from $60 on up.
Dec 22, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
How to change password
There should be a pin hole in the back of the unit use a paper clip and reset
Aug 15, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
We have a netgear neotv streaming player ntv300. We had it connected to the tv and then it had a message that it needed to be updated, so I checked it to be updated and it started updating for a whil
We had this problem too. It turned out our wi-fi signal was too weak. After we installed a wi-fi signal booster, the netgear update was completed with no further problems.
Mar 10, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Netgear ntv300 quit working
Try the reset button on the back you,ll probably need a pin as its a small hole do all that only if there,s power going to it
Jul 19, 2013 | Computers & Internet
Neo tv not loading
Reset the box.At the back of the box you can find a small hole.With a paper clip press gently for 10 secs and power off/on the box again.
Jan 23, 2013 | Netgear, Inc NETGEAR NeoTV Streaming...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
