Question about Samsung Televison & Video
Power switch wont turn on,keeps clicking
Tv model 3 lnp4042hxxaa will not turn on. power button just clicks has been takeing longer to start but now won't start at all can i repair myself? i think it might be a relay??
  • i4_ur_angel May 21, 2009
    i hope it is as easy as unplugging it because I have no idea what a fault, capacitator, convergence IC are-lol! I am just a nana trying to fix the tv so baby can watch einstien. hope it works and thanks
  • Samsung Master
  • 19,396 Answers
The fault is not a relay, the clicking sound is just the protection circuit that prevents the TV from starting because a fault had been detected.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Posted on May 21, 2009
Tv makes a clicking sound when i turn it on but wont turn on
if just only clicking sound that was mean the cause either the regulator in the power supply is bad or the horizontal output transistor get damaged.
Jul 18, 2012 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
My samsung lcd tv is clicking and wont turn on
Its a common problem with many Samsung LCD TVs. We had the same problem on our Samsung TV. Based on some info on the net we called Samsung Support department ( 1-800-SAMSUNG). After describing the problem and mentioning that I have read on the net that its a common problem, representative asked for the model number and serial number of the TV ( I read them to her from a sticker on the side of TV). The Samsung Rep acknowledged that it was a common problem for my model and few other LCD models and they were fixing the problem without any charge to customer eve though TVwas out of warranty. She took the required info and gave me the ticket/transaction number and forwarded it to a local technician. Technician called next day and setup the appointment with us. Technician came within the 4 hr window that he had promised and changed the faulty capacitor on the power board and was done within 10 mins. Samsung rep had indicated that the technician will determine if the issue was with capacitor or not. If the issue was something else then tecnician will charge the regular service charge to fix the issue.
Jul 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung tv model no LE40R74BDXIXEU TV IS USUALLY
First the main bd controls the "Turn on" sequences". When you press the Power on button the Main bd sends a "Turn on" signal to the Power supply. The clicking you hear is the Power on relay ativating. If the tv does not turn on and the relay keeps clicking then you might have a bad Main bd or there is s shorted board somewhere else in the set. The Power supply can also be bad. Have a trained Samsung tech troubleshoot the set.
Jul 12, 2009 | Samsung Televison & Video
Insignia tv will not turn on [ power up]
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 19, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
Open Questions:
Televison & Video Logo
190 people viewed this question
Jerry Greenberg
Jerry Greenberg
