While what i understand your Mitsubishi outlander, 2003 AWD having problem with wheel alignment Or a wheel barring problem kind of . and if you SUB wobbles from behind it might be problem from driving shaft or shaft crosses. its better to visit a proper mechanic to solve this problem other wise you ll facing bigger problems from this ....
bettter take care & have a save drive ...
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
You will need to contact a Mitsubishi Authorized repair facility. The entire electronics package must be removed and sent back in to Mitsubishi. The problem is the Formatter circuit board which is no longer available as a replacement part. The repair cost is very expensive and must be quoted by the facility you contact not me. Expect 4-6 weeks turnaround.
Good Day, jhazelwd;
From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
I have a 1999 Mirage 1.5 - with 225thou miles on it - my light stay's on too- I was told it was an O2 senser- but I noticed that the spark plugs come loose alot. When I tighten them and have my light reset it stays off till I need to adjsut them again-?
