Defy repair manual
The fan on our defy 731 t is loose. how do you tighten it?
2 Suggested Answers
  • 59 Answers
SOURCE: Defy 731 thermofan oven top element not working.
check the element itself visually or by a continuity tester.
Posted on Sep 21, 2013
DEFY 731 MF Thermofan oven not heating up
at the back of the oven is a over temperature protection fuse . you will have to replace it . And the reason it blows - is when the oven overheats as a result of your thermostat is U/S and most probably have to be replaced as well .
Jun 30, 2017 | Ovens
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
HI, My Kenmore Air Conditioner Model# 76129 - turns on, makes a sound like it is going to work but the fan does not move. Thanks
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
What You'll Need
You'll want to have these tools on hand to repair a room air conditioner's fan:
  • Vacuum
  • Soft cloth
  • Screwdriver or Allen wrench
  • Long-blade screwdriver
  • Wrench 20-weight nondetergent motor oil
  • Volt-ohmmeter or multimeter
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its h­ousing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season.
Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure .bobicehouse_59.jpg
Aug 13, 2011 | Kenmore 76129 Air Conditioner
Dehumidifier works fine but every now and then the fan is very noisy, as if it is loose or hitting something. Is there a way of checking to see what is happening?
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
Jul 31, 2010 | Maytag M7DH65B2A Dehumidifier
I have a defy gemini petit chef multi function themofan oven but dont have a manual on how to use would you be kind enough to let me no how to us it thanks naaz
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Apr 01, 2009 | Ovens
Washing Machines Logo
453 people viewed this question
Top Washing Machines Experts
