Question about Samsung TSL3293HF 32" TV
Audio not clear - Samsung TSL3293HF 32" TV
I have a 2009 GMC Yukon and rear speakers aren't playing
Does the system have an amplifier ?
Circuit/System Verification
Radio ON, Rear Seat Audio (RSA) OFF (if equipped), adjust the fade and balance controls on the radio to test all four channels individually. Each of the four channels should produce clear and even sound.
Without Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, replace the radio.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - without Amplifier.
With Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, refer to Amplifier Circuit Malfunction.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - with Amplifier.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the appropriate speaker.
  2. Radio ON, test for 5.0-7.5 volts between the signal circuit terminal A and ground.
  3. ?‡'
    If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
    If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
  4. Test for 5.0-7.5 volts between the signal circuit terminal B and ground.
  5. ?‡'
  6. If all circuits test normal, replace the speaker.
Apr 17, 2016 | GMC Cars & Trucks
Speaker problems
If the audio is not clear it can be caused by excessive volume, "speakers are tiny" faulty speakers, or a bad audio output chip. Plug external speakers to see if that will clean it up, if no change! audio output chip, but if problem is cured it is the laptop speakers.
Apr 29, 2012 | Dell Studio 17 (1749) Laptop black -...
Had audio but had to clear computer anb re-install
You will probrably have to install a driver to make the audio work. depending on the computer make/model will depend on the driver you need. if you go to the computer manufacturers website then they may have driver files that you can download and then install
Jan 20, 2010 | Computers & Internet
Ia looking for paint to clear paint for my car
I think you are talking about clear coat that goes over top of paint
Aug 24, 2009 | 2004 Pontiac Grand Am
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Speaker sound isnt clear for emachines speakers
DOWNLOAD NEW AUDIO DRIVER FOR YOUR CPU AND IT SHOULD FIX IT
May 14, 2009 | Audio Players & Recorders
Voice delay and low picture pixels
The problem is lack of bandwith of the receiving signal from your daughter. The Skype server is located in the UK and all video and audio data signals go to and from the Skype UK server before it goes to you and your daughter. This lack of bandwith causes the video image to break up and a delays in audio just like a weak high definition signals to your digital television.
You can see your own video and hear your own audio from your WEB cam clearly, because the video and audio data does not have to go to the UK and back again, also your satillite connection is probably not as fast as a cable broadband connection. Your daughter may also experiencing the same video and audio problems.
Video data contains a lot more information than the audio data. Therefore there are a couple of things you can do to improve the situation :-
Get your daughter to and possible you as well (if she is also experiencing break up of video and audio), to reduce the video image size from 640X480 to 320X240 resolution.
If the video is still a problem then turn off the video all together and only communicate by audio, this will reduce the amount of data being transmitted and should give you a clear/clean audio.
Dec 08, 2008 | Skype IM
Sharp tv audio problem
You may have a tunner problem. Try this turn your TV to channel 3 connect you cable to it and select a channel. If thesound has a problem what may be happening is the the audio detector may not be working properly or the audio amplification stages may not be working correctly from the audio detector. You will have to test the audio stage from the detector to the last audio amplifier to troubleshoot this problem. If you have experiences in this that's good if not take the set to a qualified service technician.
Sep 18, 2007 | Televison & Video
Sometimes my audio driver stops responding
Try this test: try repeating the "disconnecting all hardwares like DVDRW,HDD,RAMs,AGP card along with the power cables and then again re-assembled, the sound returns (this time its crystal clear) and this works for few weeks after which the problem occurs again.". Now ensure Windows restore feature is enabled. Then when "problem occurs again", revert the Windows registry back to the date when "its crystal clear". If the sound is crystal clear after restore, then you have a software or registry issue going on. If you don't mind reverting to system restore often, then stay in this recovery mode until your real problem is "crystal clear".
Aug 25, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Samsung TSL3293HF 32" TV Logo
14 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
