Question about Video Game Consoles & Games
Pedal problems clutch pedal will not depress
Clutch pedal hard to push in
Posted on Mar 02, 2014
High pitched squeal when jeep idles or during deceleration. soonafter, clutch pedal jumped violently under my foot followed by engine stalling out. could not depress clutch pedal after that.
It sounds like your clutch bearing has gone they are usually on a pendulum system it screeches before it starts to go. Best get it checked.
Apr 15, 2014 | 1995 Jeep Wrangler
My clutch won't engage 1997 Honda civic
Clutch plate and pressure plate seem to be too weak to pull the car. To test the clutch plate, park the car on flat surface. Pull the hand brake up, start the car, depress the foot brake pedal, depress the clutch pedal, put the car in 1st gear, press the gas pedal and leave the clutch pedal at once, while keeping the brake pedal depressed.
Follow one of the two following statements:
1. Engine does not shut down and remain start. (Clutch plate, pressure plate and clutch bearing defective - Replace all as a set)
2. Engine shuts down. (Clutch system is OK and does not require any repair).
Apr 06, 2013 | 1997 Honda Civic
Yo I have a 1990 honda prelude si ,I have an issue with clutch pedal, my clutch pedal seems to stick when depressed it still has good pump pressure but I have to lift it up. Now I live in Idaho and it
The pedal return spring should be checked. Also the pedal bushings where pedal connects to the pedal support up under dash may be worn and not allowing free pedal movement. Work the pedal with your hand and watch the upper mounting of the pedal to see if you can see the problem. I would expect the bushings need replaced. You might try a little light oil where the clutch pedal attaches.
Jan 15, 2013 | 2000 Honda Prelude
2002 1.3 Kia Rio. Pushed in clutch pedal, heard metallic pop, half a piece of a metal ring + half a clip sitting in driver's footwell. Pedal will depress and release but clutch wont engage
I had this same problem the cable is fine its a clip on outer cable to stop it mooving when you press clutch mine poped when I tightened the clutch cable still don't have solution though waiting to payday to take it to garage
Mar 22, 2012 | 2002 Kia Rio
Gear box problem car want start unless wiggle gear stick i fink sensor whats the problem
There is a Clutch Start Switch that allows the battery voltage to be supplied to the starter when the the clutch pedal is depressed.
When the clutch pedal is depressed, there should be continuity on terminal numbers 1 and 2.
The switch is located in front of the clutch pedal stem.
Feb 27, 2011 | Isuzu Trooper Cars & Trucks
1998 Ford Taurus SE, Problem Transmissions wont Shift, Took it to the Shop and they Said it Had to be a Electracal Problem?? But they did not Know what, Some times Works Fine Other Times Check Engine Comes...
TRY THIS I BET IT'S YOUR PROBLEM
Neutral Safety Switch
  • Put the selector in the park position.
  • Loosen the screws on the neutral safety switch.
  • Remove the switch.
  • Reverse the procedures to complete the installation.
Clutch Start Switch
CAUTION
Before replacing the clutch switch or any component connected to the vehicle's control computer, disconnect the negative cable from the battery.
  • After replacing the switch, slowly work the clutch pedal and note any unusual noises or interferences with pedal movement.
  • If the switch is adjustable, make sure the clutch pedal height and push rod (free) play are correct.
  • Then check the release point of the clutch.
  • Begin by engaging the parking brake and installing wheel chocks.
  • Start the engine and allow it to idle.
  • Without depressing the clutch pedal, slowly shift the shift lever into reverse until the gears contact.
  • Gradually depress the clutch pedal and measure the stroke distance from the point the gear noise stops (this is the release point) up to the full stroke end position.
  • If the distance is not within specifications, check the pedal height, push rod play, and pedal free play.
  • If the distance is correct, check the clearance between the switch and the pedal assembly when the clutch is fully depressed.
f_mt_tps9.26.jpg Clutch switch to pedal assembly clearance. Courtesy of Toyota Motor Company.
  • Loosen the switch and adjust its position to provide for the specified clearance.
May 22, 2010 | 1998 Ford Taurus
My '98 Escort ZX2 has 175,000 miles. I recently noticed a grinding or chattering with the clutch pedal depressed with the transmission in first gear. While stopped at a light the car suddenly began jumping...
Hi:
You need to check your clutch master cylinder reservour, not your brake cylinder. It is located approx in front of the clutch pedal, outboard of the brake cylinder. If it is low, you need to inspect for leaks around it, the lines connecting it to the clutch slave cylinder that is mounted on the transmission.
Dec 05, 2009 | Ford Escort Cars & Trucks
Clutch won't engage
There is a problem with the pressure plate spring or possibly the throwout bearing is bound up,you should be able to pull the rubber boot from around the clutch fork and have someone depress the pedal,you should be able to see if it's a problem with the bearing.Unfortunatly the trans is probably going to have to caome off.
May 25, 2009 | 1991 Toyota Pickup
Video Game Consoles & Games Logo
74 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
