Question about 60 series Diesel Power Service Manuals On-Highway
Onga pump 23930 not pumping water - 60 series Diesel Power Service Manuals On-Highway
My bathmaster v2 onga pump has a flashing red light on control pad that flashers 3 times with 1 sec intervals pump does not work please help
if the controller is flashing it means that there is no water to pump
check water supply to the pump
Jun 01, 2016 | Cars & Trucks
Big rainwater tank ran dry and so electric Onga pump that normally pumps water from big tank to little overhead tank kept failing. Have since refilled big rainwater tank, but pump keeps failing. Have
Release AIR lock. Air has got trapped in the pump hence it cannot create necessary level of suction. The way normally you do this by filling the water path of the pump with water and get the air released.
Oct 12, 2014 | Plumbing
Water house pump not working
More information would be helpful. Did it freeze? Why is it hard to reset, is it because you did not waite a few minuts befoe resetting.
Jan 02, 2014 | Plumbing
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
I have a Lanark double spa with a Onga 23930 pump. The jets are not working and we think that maybe the pump has air in it. It is possible the it took air in when I was cleaning around the spa controls and...
fill the tub with water and then turn the pump on. Get under the tub next to the pump and loosen the union on the discharge of the pump until some water starts coming out. If you have an air lock this will relief that and the pump should start pushing water to the jets.
US Parts Center
Aug 22, 2011 | Pool & Spa
My electric onga water pump which pumps water from my watertank to the house will not turn off. I have looked for a leak but cannot find one.
What is the model of the pump? What type of control does it have - pressure switch, electronic controller or what?
Jul 30, 2011 | Computers & Internet
Have an Onga JJ400 jet water pump several years old, pump is working but delivering poor water flow
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Jun 29, 2011 | Plumbing
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Sep 07, 2009 | Plumbing
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
60 series Diesel Power Service Manuals On-Highway Logo
37 people viewed this question
Top Detroit Red Vehicle Parts & Accessories Experts
Lawrence Oravetz
Gloria Vernon
Gloria Vernon
Level 1 Expert
Lucy Angela
Lucy Angela
Are you a Detroit Red Vehicle Part and Accessory Expert? Answer questions, earn points and help others
