Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI-84 Plus Silver Edition turns off immediately, all batteries have been replaced, but unit still turns off. I even replaced the memory battery.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
You may need to reset calculator. Take ou the batteries and the backup battery. Leave them out for about 8 hours. Then put everything back in. Hopefully this will work.
Posted on Aug 06, 2009
Repair ti 84 plus silver edition
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2014 | Office Equipment & Supplies
Is there areset button my keys are frozen
Unfortunately, you can only access RESET from within the menus of the calculator. You will have to remove all of the batteries and let the system naturally reset. The TI-84 Plus uses five batteries: four AAA alkaline batteries and one SR44SW or 303 silver oxide backup battery. The silver oxide battery provides auxiliary power to retain memory while you replace the AAA batteries. Re-install the batteries and reprogram your functions.
Oct 23, 2011 | Texas Instruments TI-84 Plus Silver...
Hi, i was wondering if you can help me with my ti-84 plus silver edition calculator. The problem is that it simply won't turn on, even with NEW batteries. Thank you
1. Check the battery holding area and make sure that all of the connectors are protruding enouugh for the batteries to make a good connection.
2. Check the diagram for exact polarity placement.
3. If still no power, try using you electrical plug for power. The problem could be with a connector and you may have to purchase a new TI.
Nov 16, 2010 | Texas Instruments TI-84 Plus Silver...
My ti 84 plus silver edition wont turn on. I
If that doesn't work, add a comment to this post and we'll go from there.
May 31, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Silver Edition not responding!
what helped for me is leaving it w/h any battery's (no backup battery either) for a few days. Now miraculously it works!
May 06, 2010 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
My TI-84 silver edition has frozen, It is stuck on the same screen and nothing appears when I hit buttons, it wont even turn off. When I remove the batteries and place them back in the same screen appears....
I had the same problem. I remove all four batteries and the battery backup that is underneath the little phillips screw in the battery compartment. I immediately replaced it and the other batteries and everything worked. FYI, others have called for keeping the batteries out for 8 hours.
Apr 06, 2009 | Texas Instruments TI-84 Plus Silver...
My daughter's math teacher cleared her ti-84 plus silver edition calculator for the algebra regents but never put the software back in. how do I get her graphing calculator back to the way it was...
My screen was frozen and I needed to do a manual reset. If you take out 1 battery from the back....hold the "del" key down and reinsert the battery while holding it down....it will reload the programming into the calc
Aug 16, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
758 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
