Question about HP Color LaserJet 2600n Printer
HP LaserJet 2100/TN
This is a 2100 (not a 2600 as noted below. The drop down menu didn't list the 2100.)
The Model # is C4172A. Serial # USCB030991.
It seems to me to be a paper pulling problem. But I'm asking you because you're the expert, not I.
Here's what happens. The image prints for a second time further down on the same piece of paper.
The front slot feed for envelopes, etc. seems to work ok.
Could you tell me what's up and what I'll need to purchase in the way of parts?
Thank you.
Fuzzball
  • HP Master
  • 1,113 Answers
Replace toner cartridge drum/blade RS, slim faint outside chance it is a fuser (hot bit rear) problem, doubt feed issue
To confiirm to yourself it isn't a feed issue, try feeding A4 via manual bypass (envelope slot) and doing a print using manual bypass tray, just override size missmatch warning if it appears (tick i think when beeping). should do same fault as feeding via cassete
You can also print a test page from printer via operations panel to confirm it is printer problem not software.and you can do a paper path test from whatever feed slot
To eliminate it being fuser problem try printing and turning the power off when paper is 1/2 way threw print job, remove cartridge and exaimine unfused (still image rubs off) print, if image is fine then it is a fuser issue but be carefull to note how much of a page needs to be printed before image repeats so you know if it is right or wrong.
But thats just tecnical possibitys, Change cartridge should fix!
Odds are 95% cart 4% fuser 1% others i reckon!
Posted on Oct 19, 2007
SOURCE:
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
How to install HP C4172A Hewlett-packard laserjet 2100tn laser printer on my laptop ..i dont have cd
Go to the HP website, click on "support" then "software and drivers",
key in either HP2100tn or C4172a into the entry field and follow the trail from there. If there is a driver available for your operating system (you should check that in control panel-system ) you can download and install it.
HP LaserJet 2100tn Printer
Sep 23, 2013 | HP C4172A Hewlett-packard laserjet 2100tn...
How can I set the IP address of my old HP LaserJet 2100 TN printer?
Remove the printer from your computer then reinstall.
May 03, 2012 | HP LaserJet 2100 Printer
I got a new computer but an old printer and I need the driver for it. It's a Hp officejet 2100 tn. I worried I'm going to download the wrong one and get virus's.
All versions of windows since Win XP have had the driver for the Laserjet 2100 built in. When you connect your printer to the computer and reboot it should say 'found new hardware' and load the correct driver automatically.
Sep 23, 2011 | HP LaserJet 2100 Printer
Hi, my printer is printing a test page but it's not clear at the left side of my page.what could be the cause of this problem?it's hp laserjet 2100/m/tn
This may be one of several things.
When you rub your finger over the unclear parts, does the image come off and feel grainy.
If so your fuser unit is not fusing the image corectly.
Have you tried another drum unit in the machine, it may be that the problem is on the drum unit and that the image is not transferd corectly.
Feb 10, 2011 | HP LaserJet 2100 Printer
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
Will not print lines like this _____
Try reinstalling the driver, you can get updated drivers from HP
Feb 27, 2009 | HP LaserJet 2100 Printer
Need A Manual
HP has a pdf manual online for your model.
Here is the URL link for the HP LaserJet 2100.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=25469
Nov 28, 2007 | HP LaserJet 2100 Printer
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
HP Color LaserJet 2600n Printer Logo
218 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
